| Version(s): | 10.00.00.25 | ||
| Area: | Properties | ||
| Subarea: | Item Types |
A property type is a collection of properties, which can be used by any item type in the same library.
• Load the Item Type dialog by keying in “dialog itemtype”
• Click on the “New Property Type” icon
and create a new property “Address”
• Select the newly created property type “Address” and click on the “New Property Definition” icon
to create the required properties (Street, City, State, and Zip).
• Click the “Save”
button to save the item type settings to the design file.
• Check the Property Type list box, which should display the new created property definition “Address”.
| Original Author: | Leonard Jones |
