| Version(s): | N\A | ||
| Area: | Animation | ||
| Subarea: | N\A | ||
| Original Author: | Ignacio Balestra, Bentley Technical Support Group |
Solar Study, Speed, single images.
User is making sequence of jpg images with Solar Study. How does Speed value affect the number of images created?.
Speed value will not affect creation sequence of jpg images, it will only have influence on animation.
If you go to menu > Utilities > Image > Movies it will open the Movies manager where you could load the sequence of jpg images and make a movie. In this Movie tool if you go to Settings>Playback> you could change the speed of how movie will play.
