This PDF document contains a detailed, step by step guide in creating C# WPF Addins for MicroStation and ORD.
The guide walks you through the following topics
While the SDK documentation had some good examples, it still took me some time to figure out how to set up everything. Hopefully this guide will help others.
This .zip file is the source code for everything the document goes through.
This Guide and supporting materials is provided as a reference only, USE AT YOUR OWN RISK!
