This video talks about the upcoming update to the drainage and utilities dgnlib, the reason for the update and how to fix existing projects after this is pushed out.
After this update is pushed any existing worksets that have already used drainage & Utility features (created a Drainage and Utilities Project) then that project MUST be updated to keep using the old dgnlib.
the goal of this video is to show you how to do this. After this update it pushed out simply add the below line to the end of the worksets cfg file.
%include $(_USTN_WORKSPACESTANDARDS)\config\WorkSetConfigSwitchVarstoOldSUDA.cfg
