Fix Duplicate Profile Annotations
The 2020 release of OpenRoads Designer, version 10.08.00.88, adds the ability to annotate profile vertical curve data with dimension lines when generating sheets.
ODOT has updated the curve data annotation with the May 1, 2020 release of the OHDOT CADD Standards to add dimension lines to the vertical curve annotation. This can result in duplicate annotations if your alignment and profile were defined prior to the May 1, 2020 standards update.
This video will show you how to update the annotation definition for the Profile Linear Feature Definition to remove the duplicate annotations.
https://youtu.be/50siD8HXhTk
