Sheets
The following videos are available for reference that pertain to survey topics.
Import Survey Data from CSV
Reviewing Survey Data
Terrain Model Creation and Editing
Creating a Complex Terrain
Creating a Terrain Model from a Point Cloud
Importing a Shapefile from ProjectWise
Adding a Linear Feature to an Existing Field Book
Terrain Model to Terrain Model Heat Map
Leica ASCII Export/Import (FRT)
