Drainage & Utilities
Drainage and Utilities
The following KB articles are available:
New Drainage & Utility Features - Fix compatibility issue
Extracting Utility Features
Modifying/Custom Utility Profiles
Extracting Existing Drainage Features
Placing Headwalls
Modeling Proposed Drainage Features - Placing Nodes and Conduit
Modeling Proposed Drainage Features - Place Nodes Tool
Creating Profile Runs
Profile Run Sheets
Setting up Drainage to show on Plan And Profile Sheets
Showing Drainage on Plan and Profile Sheets
Setting up Utilities to show on Plan and Profile Sheets
Setting up Utilities to show on Plan and Profile Sheets - Alternative Workflow
Showing Utilities on Plan and Profile Sheets
Drainage and Utilities Annotation Overview
See
this
time stamped video for Drainage and Utility Annotation
Plan view Drainage Annotation
Profile View Drainage Annotation
Cross Section View Drainage Annotation
Station Offset Annotation - Drainage Annotation
Annotating Utilities in Profile Views
Annotating Utilities in Cross Section Views
Importing User Defined Extensions into Existing Projects
Custom Conduit Sizes in ORD Drainage
Custom Conduit Sizes in ORD Utilities
Changing Defaults for Utility Extraction
