Profile View
Profile View is one of seven viewing selections in the Graphic View Panel, providing users with a span-centric view from the active location to a selected wire end point (WEP). This view allows users to measure clearances between wires and to the ground at any point along the span, define different weather conditions for each usage group, and model changing topography.
Profile View Tools
Within Profile View, users can utilize the dropdown menu in the top left to switch between spans on the active location, if more than one WEP is present in a project.
Additionally, the Profile View Toolset consists of several buttons to help users evaluate clearances on the selected span:
