| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Report |
| Date Logged & Current Version | Nov 2017 11.01.00.23 |
How to calculate Bolt Tensile Stress from Flange Analysis output report?
The bolt tensile strength is broken into two parts of the report: Operating Conditions and Gasket Seating Conditions. The equations used to calculate the Bolt Tensile Stress for each section as followed:
Note: Flange analysis based on Walkthru.DAT example model.
