Attention: Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Modeling Approaches> Modeling Approaches>
This help has been provided in order to give users ideas for modeling typical piping arrangements. The steps shown in each example should not be taken as the only method available to create models. In addition, the intent of the examples is to present ways to create adequate models of specific piping components for analytic purposes.
Anchors Bends
Cuts Flexible Joints
Frames Hangers
Nozzles Pipes
Reducers Rotating Equipment
Supports Tees
Valves Vessels
Notes:
- AutoPIPE does apply thermal expansion coefficients to VALVE components. The corresponding Temperature load case, (ex. T1, ..Tn) and expansion parameters on the Press/Temp/PipeID input grids are used to determine how much expansion will occur.
- Stiffness of a valve component is 100 times the stiffness of the defined piping ID. Meanwhile the stiffness for rigid pipe is by default 1000 times the stiffness of the defined piping ID. However, the user can change the rigid stiffness used by the program (search "Rigid stiffness factor").
- When selecting the Valve Manufacture, Standard, subcategory, and Type settings on the valve dialog, specific available library data will be used. However, using the AutoPIPE Generic selection, the same valve can be modeled. Only difference is that the user will need to manually enter data instead of using automatic library data.
Comments, Questions, and Answers:
- Model Approach:
- 3-way valve
- Angle valve (90 deg valve)
- Pressure relief valve
- Fire hose valve
- Butterfly valve
- Reducing valve
- Complex valve (ex. Bell & Gossett Triple Duty Valve)
- Large double offset valve
- Valve actuator and support
- Valve + actuator based on catalog info with combined values
- Valve submerged in water
- Surface Area factor and calculation
- Stiffness value of a valve
- Drop down listing issues:
- Specific valve missing - General Modeling approach
- Pressure rating list only NS (Non-Standard)
- Flange / Valve rating not listed
- Missing specific information?
- Why is wrong weight used when inserting a valve?
When inserting a valve with flanged end connections on both side, the wrong weight is automatically applied to the flanges. example: add a GateF Class 300 valve and tick the insert flanges option the flanges by default are the same weight as the valve.
Answer:
This is a known issue and has been logged under CAE-TR-10614 Using insert flange on both ends copies the weight of valve to flange and was fixed in AutoPIPE V8i 09.06.00.07 and higher.
Model Different Types of PIPING Components
