18. Support Enhancements & Defects in AutoPIPE
Note: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Bug 1536259 :
Input Grid: Changing support type from hanger to non-hanger does not zero out cold load
Bug 1515875:
Results liftoff support command filter is too restrictive
Feature 1053714:
Add feature to select specific spring
Feature 860319:
Add UnisonHKR spring hangers catalog
Feature 745885:
Add Kinetics Noise Control Springs and Cans
Enhancement 1036842:
Provide a slip bi-linear type directional pipe support
Enhancement 1035158:
Add option to activate support dampers in the User cases
Enhancement 1019651:
OPIM: Add support symbols for vertical pipes
Enhancement 696146:
Add Forward / Back gap to damper support
Enhancement 439677:
Add spring hanger data for Bergen Pipe Support Group (PSL) to libraries
Enhancement 338825:
Enhancement 114740 (CAE-CR-6237) :
Allow gaping of rotational support
Enhancement 138946 (CAE-CR-10939) :
Update damper support to viscous damper
Enhancement 138703 (CAE-CR-10654):
Enable spring support bearing direction to be user-specified
Enhancement 111597 (CAE-CR-2984):
Add a Six way anchor restraint or support component
Enhancements Requests and Logged Defects
