AutoPIPE CONNECT v.12.02.00.14 - Read Me file
What is New & Changed in AutoPIPE®
AutoPIPE CONNECT Edition version 12.2 (v12.02.00.14:2019-09)
The following outline identifies new features and enhancements in the AutoPIPE CONNECT Edition version 12.02.00.14.
  [Technology Preview ]
Technology Previews provide users preliminary access to features currently in development but not yet ready for production. These features are provided at no additional charge to promote awareness of a feature or technology to be deployed in a future release. Users are encouraged to provide feedback and suggestions. To learn more about Technology Previews, please create a Service Request (be sure to include "Technology Preview" in the Description field).
AutoPIPE®  Requirements
Product Version
ProductAutoPIPE
Versionv12.02.00.14
LanguageEnglish
Included Applications Versions
PCF Translatorv1.0.0.81
Straitv6.0.0.16
BatchGenv1.0.0.4
ADL2NTLv1.0.0.22
Nozzlev8.11.8.35
OPIMv10.05.00.27
Connect Advisorv10.01.00.154
Connection Clientv10.00.17.10
Installation Requirements
CD drive or access to the Internet required for product installation. The minimum system configuration for installation:
Operating SystemMicrosoft Windows 7 Professional or higher (with Service Pack 1)
Microsoft Windows 8 Professional or higher
Microsoft Windows 8.1 Professional or higher (with KB2919355 Update)
Microsoft Windows 10 Professional or higher
32 or 64 bit OS
.NET Framework3.5 SP1
4.6.1
When installing the product through the installer program, the required components will be installed automatically. The contents of the Desktop Prerequisite Pack include:
Minimum Profile
The minimum recommended workstation profile for running AutoPIPE is:
ProcessorIntel Pentium IV or higher.
Memory1 GB recommended. More memory almost always improves performance, particularly when working with larger models.
Hard Disk1 GB free disk space (not including Restore Point space requirements).
Video Graphics CardAny industry-standard video card which supports OpenGL 3D graphics.
ProjectWiseProjectWise Server 10.00.03.235 with ProjectWise Explorer 10.00.03.235, ProjectWise Server 10.00.03.140 with ProjectWise Explorer 10.00.03.140, ProjectWise Server 10.0.1.67 with ProjectWise Explorer 10.0.1.67, ProjectWise Server 10.0.0 with ProjectWise Explorer 10.0.0.11 or higher, ProjectWise Server 8.11.7 with ProjectWise Explorer 8.11.7.133 or higher, ProjectWise Server 8.11.9 with ProjectWise Explorer 8.11.9, ProjectWise Server 8.11.11 with ProjectWise Explorer 8.11.11.
OpenPlant Isometrics ManagerCONNECT Edition Update 5 - 10.05.00.027
PDF ReaderAdobe® Acrobat Reader 7.0 or greater
Download and Installation
See the AutoPIPE Quick Start Guide (..\Documents\Quickstart_AutoPIPE.pdf) for more information on downloading and installing AutoPIPE.
To complete the licensing process, you must have the appropriate roles assigned by your Site Administrator. If you have not been assigned these roles, you will need to obtain the name of your Site Administrator by submitting a Service Request at http://apps.bentley.com/srmanager/ProductSupport.
If you are experiencing problems logging into your Bentley account, please contact bentley at 1-800-BENTLEY (1-800-236-8539). Outside the United States +1 610-458-5000.
Network Considerations - Network drives are only supported for data files.
Applications Included in the Installation Package
AutoPIPE Standard, AutoPIPE Advanced, AutoPIPE Nuclear, and add-ons are installed from one executable.
NOTE: For further information on translators, please refer to their respective readme files.
Documentation
Program Help: Detailed feature information may be accessed directly from the calling application by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions. A set of supplemental How To, Tutorial, and Reference Information documents in PDF format are provided in the Supplemental Documentation folder (Bentley AutoPIPE > Supplemental Information) of the main Program Help file (autopipe.chm).
Tutorials: Documentation for AutoPIPE applications is provided online in the Adobe.pdf format. These files are accessible from the Help Menu. All documents can be browsed, searched, or printed with the Adobe Acrobat Reader. Information and how to download a FREE copy of the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
Piping Codes
Standard Edition Piping Codes
Piping CodeDescriptionEditions
B31.1 PowerPower Piping1967, 1986, 1992, 2004, 2005 Addenda, 2007, 2009 Addenda, 2010, 2012, 2014, 2016, 2018
B31.3 Process PipingProcess Piping2004, 2006, 2008, 2010, 2012, 2014, 2016
B31.4 Liquid Trans.Liquid Transportation Systems for Hydrocarbons, Liquid Petroleum Gas, Anhydrous Ammonia and Alcohols2006, 2009, 2012, 2016
B31.8 Gas Trans. & Dist.Gas Transmission and Distribution Piping Systems2003, 2007, 2010, 2012, 2014, 2016
EN 13480European Piping Code for Metallic Industrial Piping2002, 2010 Addenda, 2012, 2017
GeneralGeneral Piping CodeNot Required
ASME B31JStress Intensification Factors, Flexibility Factors, and Sustained Stress Factors used in B31 Piping Analysis2017
Extra Codes Available in AutoPIPE Advanced Edition
AutoPIPE Advanced includes all codes available in AutoPIPE Standard, as well as the following codes.
CSA-Z662Canadian Standards Association, Oil and Gas Pipeline System1999, 2007, 2011, 2015
CSA-Z662 OffshoreCanadian Standards Association, Offshore Steel Pipelines1999, 2007, 2011, 2015
BS 806Design and Construction of Ferrous Piping Installations for and in Connection with Land Boilers1993
BS 7159Design and Construction of Glass Reinforced Plastics (GRP) Piping Systems for Individual Plants or Sites1989
SPC-2Swedish Piping Code, Method 21978
TBK5-6General Rules for Piping, The Norwegian Pressure Vessel Committee1990
STOOMWEZENDutch Piping Rule D1101 of the Rules for Pressure Vessels1978
DNV OffshoreDet Norske Veritas, Rules for Submarine Pipelines1981, 2012
MITI 501 3-1980MITI 501 Class III Piping Code1980
KHKKHK E 012 Piping Code, Seismic Level 1 or 2 (Seismic Level 2 requires a KHK 2 Add-On license)2006
RCC-MFrench Piping Code for Power Industry1985
SNCTFrench Piping Code for Process Industry1985
SNIP Russian 2.05.06-85 Oil & GasRussian SNIP piping code for oil and gas1997
ISO 14692Petroleum and Natural Gas Industries - Glass Reinforced Plastics (GRP) Piping2002+2005 addenda
B31.4 OffshoreOffshore Liquid Piping Systems2006, 2009, 2012, 2016
B31.8 OffshoreOffshore Gas Transmission2003, 2007, 2010, 2012, 2014, 2016
Extra Codes Available in AutoPIPE Nuclear Edition
AutoPIPE Nuclear includes all codes available in AutoPIPE Standard and AutoPIPE Advanced, as well as the following codes.
ASME NB NuclearBoiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NC, Class 1 Components1972 W Addenda, 1975 W Addenda, 1977, 1982 W Addenda, 1983 W Addenda, 1988 Addenda, 1989, 1989 Addenda, 1993 Addenda, 1994 Addenda, 1997 Addenda, 1998, 2001, 2004, 2007, 2008 Addenda, 2010, 2011 Addenda, 2013, 2015, 2017
ASME NC NuclearBoiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NC, Class 2 Components1972 W Addenda, 1975 W Addenda, 1977, 1980 S Addenda, 1983 W Addenda, 1988 Addenda, 1989, 1989 Addenda, 1993 Addenda, 1994 Addenda, 1997 Addenda, 1998, 2001, 2003 Addenda, 2004, 2007, 2008 Addenda, 2010, 2011 Addenda, 2013, 2015, 2017
ASME ND NuclearBoiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection ND, Class 3 Components1972 W Addenda, 1975 W Addenda, 1977, 1980 S Addenda, 1983 W Addenda, 1988 Addenda, 1989, 1989 Addenda, 1993 Addenda, 1994 Addenda, 1997 Addenda, 1998, 2001, 2003 Addenda, 2004, 2007, 2008 Addenda, 2010, 2011 Addenda, 2013, 2015, 2017
JSME PPC NuclearJSME S NC1: Rules on Design and Construction for Nuclear Power Plants, Class 2 Piping2005, 2008
How to Activate AutoPIPE®
Subscription Entitlement Service is Bentley's new licensing model, providing enhanced security and optimized value for your Bentley Subscriptions. It is integrated with Bentley's Identity Management System (IMS) and the Bentley CONNECT technology platform to allow near real-time reporting of usage, improved alert messaging to users and increased administrative capabilities to license administrators in your organization. It will not only give you more options to monitor and manage usage but also provide new, advanced licensing features that will enhance digital workflows.
Activation
With Subscription Entitlement Service, all users must be registered with Bentley's Identity Management System (IMS) and sign in to the CONNECTION Client to access Bentley applications. Product activation will now occur through user sign-in to the CONNECTION Client with a valid IMS ID associated with their account. User sign-in will replace traditional activation keys, offering enhanced security as administrators will be able to control which users have access to Bentley software. License entitlements are granted and maintained through Subscription Entitlement Service's Entitlement Management Service. By signing into the CONNECTION Client users can also find their organization's projects, download software updates, receive relevant notifications, and track their usage.
Alerts
Subscription Entitlement Service features the new license alerts notifications that can be set by an organization's license administrators to let the users know when they reach a set usage threshold. These notifications will alert the users that if they continue to use the product, a term license may be issued. The user in such a situation has the choice to quit the application before a license is used or acknowledge that a term license may be generated and proceed with starting the application, based on what settings the administrator chooses.
Error History
AutoPIPE v12.2.0
The following outline identifies all major errors fixed in Release of AutoPIPE v12.2.
When inserting a new valve, program loads the insert valve dialog with the data from previously inserted valve. The displayed length, weight and surface area factor may not be correct for the new valve if the pipe nominal size is different from the previously inserted valve. If the user clicks ‘OK’ on the insert valve dialog without making any changes, the incorrect length, weight and/or surface area factor will be saved in the model. This use of incorrect value of weight and/or surface area factor in the analysis and stress calculations may lead to un-conservative results.
This issue is limited to Standard valves only and is not applicable to Non-Standard Valves i.e. valves with 'NS' selected as Standard.
When evaluating pre-verification and full verification stresses, bend mid points inherit the stress indices of the associated far point. For split mid points, reporting both a -ve and a +ve face, the +ve face of the mid-point will inherit the stress indices of the +ve face of the far point, which is considered a run or straight pipe in AutoPIPE. Additionally, regardless if the mid-point is two-faced or single-faced, if a User Joint and SIF is applied to the far point to override the default stress indices, the mid-point will also inherit this joint data. Incorrect SIF calculations on the bend mid-point +ve face will decrease the stress results in the pre-verification and full-verification reports, which is unconservative. Additionally, due to AutoPIPE’s behavior of applying stress indices to soil points, all soil points following a mid-point +ve face and preceding the far point -ve face (i.e. soil points between the mid-point and far-point) will have the same incorrect stress indices, taken from the +ve face of the mid-point.
When evaluating ASME NB equation 11 for tee points, AutoPIPE calculates both the linear temperature distribution and non-linear temperature distribution terms using Modulus of Elasticity, Thermal Expansion, and Poisson’s ratio from the second header leg always. These terms are calculated in AutoPIPE under the assumption that the material properties for all tee legs are the same. However, AutoPIPE is also capable of supporting different materials for each tee leg, independent of the other tee legs. Using the pipe material properties from the second header leg only when determining wall gradient stresses can result in a lower stress value, which can lead to unconservative results.
ASME B31J provides details on calculation of tee flexibility factors. These flexibility factors are provided in the tee local coordinates (in-plane, out-plane, and torsional) and relationships to calculate tee branch and header stiffness values using these flexibility factors in tee local coordinates are provided. AutoPIPE requires transformation of these stiffnesses into the element (header or branch legs) local coordinate system to compliment the element stiffness matrix. A defect exists in AutoPIPE during the transformation of the B31J stiffnesses from the tee local to element local coordinates. This defective transformation produces incorrect stiffnesses of tees that are skewed off at least one global axis. This stiffness error is carried through to displacement, forces & moments, and stress results.
For ASME NB code, equation 9 pressure term calculations for a tee point uses the maximum D/t from the Header and Branch pipes. ASME NB requires using D/t ratio of the header pipe for the pressure term calculations. Using higher D/t ratio from header and branch is conservative in nature and may results in reporting higher stress value than the actual stress value required by ASME NB.
Axial pressure force may not be included in longitudinal pressure stress calculations for Hydrotest code combination. Although the pressure case is included in the Hydrotest combination, however, the axial pressure force value is not accounted for when calculating the longitudinal pressure stress value.
As required by ASME VIII Division 1, Mandatory Appendix 2, section 2-1(b), all calculations shall be made on dimensions in the corroded condition. AutoPIPE's flange check analysis does not support consideration of corrosion allowable on flanges.
NOTE: Please contact Bentley TSG for more details.
Bentley Copyright Notice
Trademark Notice
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
Copyright Notice
© 2019, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the "AutoPIPE CONNECT v12" folder of the product installation. By default, this location is "C:\Program Files (x86)\Bentley\AutoPIPE CONNECT v12".
Corporate Headquarters
685 Stockton Drive
Exton, PA 19341-0678 USA
Phone: (1) 610 458-5000
FAX: (1) 610 458-1060
WWW: http://www.bentley.com/
International Headquarters
Bentley Systems Europe B.V.
Wegalaan 2
2132 JC Hoofddorp
THE NETHERLANDS
Phone: (31) 23 556 0560
FAX: (31) 23 556 0565
WWW: http://www.bentley.com/nl-NL/
Asia Headquarters
Bentley Engineering Software Systems
Unit 1402-06, Tower 1
China Central Place, Beijing 100022
CHINA
Phone: (86) 10 5929 7000
FAX: (86) 10 5929 7001
WWW: http://www.bentley.com/zh-CN/
