01c. Model Non-metallic Plastic Piping (i.e. Plastic, PVC, PP, PPR, HDPE, PE, FRP, GRP, etc.)
Comments, Questions, and Answers
Notes:
1. Typical modeling approaches of non-metallic piping:
- On demand training documents:
- Non Metallic Piping Analysis in AutoPIPE
- YouTube video  - Non Metallic Piping Codes
- See AutoPIPE Help Supplemental documentation, tutorial section:
- ASME B311 With HDPE Tutorial
- ASME ND With HDPE Tutorial
- ISO 14692 FRP Tutorial
  1. Why is it not possible to use elbows with HDPE pipe as with steel pipe?
  2. Calculate HDPE pipe using any other (non-nuclear) code than N-755-1
  3. Add Seismic load case "Seis Ind Cmb.1-HDPE{1}" for HDPE combinations for ASME 31.1 piping code
  4. Enable "HDPE Material" option on the Pipe Properties dialog screen
  5. Can FRP material be defined in a CSA-Z662 code model?
    • Answer: Yes, set Pipe ID material = NS (Non-Standard), and enter the correct values of allowable, modulus and other data required for calculations.
  6.
Modeling Approaches
