Q18. What is the meaning of the number printed in brackets for each AutoPIPE combinations, ex Amb to
Product(s):AutoPIPE
Version(s):ALL;
Area: Reports
Date Logged
& Current Version
Aug. 2022
12.08.01.010
Problem:
What is the meaning of the number printed in brackets for each AutoPIPE combinations, ex Amb to T2 {3}?
 Simple, that number pertains to which Static Analysis Set that a specific combination belongs to.
Example:
Given the following Analysis set configuration and output report shown above, what does Amb to T2 {3} mean :
One can clearly understand that Amb to T2 is a load case combination pertaining to Analysis set #3. Without this number how could one distinguish the results from same combination names as indicated by Analysis Set #2 or #3.
See AutoPIPE help for "Combination Options" for minimal control over displaying this information.
FAQ on reports
