"Code Compliance" sub-report using Results> Output Report in AutoPIPE
Comments, Questions, and Answers:
Note:
  1. See "Piping Code Calculations - AutoPIPE" wiki for more Code specific calculations and reporting errors
  2. AutoPIPE does not print Code stress results when last components modeled are element (ex. flexible joint, nozzle element, etc..) and anchor. insert a short pipe run between the elements to see code stress results.
  1. What is the meaning of:
  2. Why are Code stress results different after adding an extra node point to pipe run / bend?
  3. Hoop related questions
  4. Stresses results for gravity load-case only
  5. Thermal loading does not seem to be applied in the axial direction, why?
  6. SIF questions and answers
  7. Stress results greater for a slower wind speed than a higher wind speed
  8. "Max Range {TR]" does not match the indicated combination value or any of the other Expansion combination values, why?
  9. What to do when dynamic Response Spectrum exceeds a code allowable?
  10. Why are there no normal Code Combination results, only HDPE combinations?
  11. Output report / Results grids, Code Stress results are completely blank , why?
  12. Considering that E2=-E1 why are the combinations GRTP2-E1 & GRTP2+E2 results not the same?
  13. Appear to be using the valve material when computing the allowable stresses
  14. What physical properties (OD and thickness) are used at welded elbows to calculate the Indices, Stiffness, Flexibility, Section Modulus, and Pressure Stiffness using the ASME NB code?
  15. Over stress due to Harmonic loading?
  16. Over stress due to Hydrotest load-case?
  17. Results for a combination subtracting dynamic load cases (ex. GRT1P1 +U1 -S1 -R1) are higher than when adding the same dynamic load cases (ex. GRT1P1 +U1 +S1 +R1)
  18. Would code stress results be the same regardless of which piping code was used
  19. Bending stress analysis results does not match hand calculations
  20. Time History Results on symmetric model does not match
Analysis Sub-reports FAQ
Custom Reporting Capabilities
Reports
