"Bentley AutoPIPE" Messages displayed in AutoPIPE
Bentley OpenPLANT Isometrics Manager not found / is not installed
Cannot insert Component after a tee. Please insert a pipe run first.
Error:
Bentley CONNECT Licensing system is not installed
Error in writing Point file.Type mismatch
Error in writing Pres/Temp/PipeID file.Type mismatch
Error in writing Section ID file.Type mismatch
Error in writing Soil file.Type mismatch
Error in writing Tee file.Type mismatch
Error in writing Valve file.Type mismatch
Error opening file: xxxx.L001
Error Writing Files
H/D is greater than 14.0
Please Analyze the Model First. The Load Table values can only be set if modal analysis results exist
Please select a valid test pressure
case for B31.3 test pressure update
Program failed to generate SQlite Database...
Program has detected disconnect in selected Pipeline which is not supported...
Query is too complex
Report Generator Error: Program failed to merge documents.
Ring components are not permitted in HDPE pipe system as per CC N-755-1
Selection types different
SmartPlant translator not installed
Stress Isometrics are only available with Nuclear or Advanced edition
The Gasket Dimensions are not available for Gasket Type [Ring Joint] for Rating = 900 having Nominal Pipe Size of 36.000000 inch.
The Gasket Material [SPIRAL-WOUND ALLOY WITH MINERAL FIBER FILL] is not available in the GasketMaterials Table.
The required information is missing for this flange.
The value should be in range 0.010 to 10.000
Unable to generate Stress Isometric....
Unable to open the asme2010.mdb database
W88-24: Allowable based on cold yield Sy may be un-conservative
Warnings, Errors, Crashed, Confirm Messages
