| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Modeling |
| Date Logged & Current Version |
June 2022 12.08.00.063 |
Limitations of inserting a model from STAAD into AutoPIPE using PipeLInk.
With the use of PipeLink, an advanced structural model data exchange, model data can be exchanged between STAAD.Pro and AutoPIPE. PipeLink provides a plug-in interface in STAAD.Pro for the exchange of structural information, e.g. structural geometry, boundary conditions, load information, and displacement information to an intermediate database file (*.pipelink), which can then be read by AutoPIPE. The process of inserting a model from STAAD.Pro into an existing AutoPIPE model is described below.
As of June 2022, AutoPIPE 12.08:
| Imported STAAD Information |
| Limitations |
1. Member loads cannot be imported for beams.
2. Import Imposed Point Dead Loads
3. Unsupported beam sections will be imported as Non-Standard and drawn as an I-beam.
Unsupported sections are those where only STAAD has the functionality to create and analyze such sections (ex. tapered sections, user defined sections, etc.. ) , but not currently available in AutoPIPE (June 2022). Only being able to define the section is not enough. AutoPIPE would then need the capability to be able to analyze these sections as well. This ability will be added to AutoPIPE in a future version after ISM in STAAD.
4. As of AutoPIPE 9.6, multiple models from multiple PipeLink files can now be inserted.
5. When importing beam releases, AutoPIPE is limited to three degrees of freedom, i.e. axial (translation), Y-Y and Z-Z (rotational). Moreover, AutoPIPE cannot handle partial beam releases. Therefore, any beam releases that do not fall into those degrees of freedom, or are partially released, will be ignored.
6. Any changes in structural nodes and members are not exported and will be lost on a subsequent import.
7. Material Name is appearing empty. AutoPIPE allows for maximum of 16 characters, whereas STAAD allows for more than 16 characters. Workaround for material name issue is to have 16 characters at max for material name in STAAD.
8. Beams with same name in a subsequent import will be renamed to 1.2, 2.2, 3.2 respectively
9. Delete > Structure > Structural Model, The following will be removed from the model
10. Only individual load cases are imported from STAAD.
Structural codes require specific code combinations, while Piping codes have their own distinct code combinations. Although some fundamental combinations may overlap between the two, a significant number of combinations are unique to each type of analysis (Structural vs Piping). Consequently, it is advisable for the user to focus solely on the appropriate combinations relevant to each application, rather than attempting to manage all combinations from both applications in each other analysis.
Attempting to handle all combinations across both applications by adding user combinations can be quite challenging and may exceed the capability of the application.
11. AutoPIPE Components (ex. Bend, Tee, Reducer, Flange, Valve, Flexible Joint, etc..)
When an AutoPIPE pipe stress model is imported into Bentley STAAD, the intent is structural load transfer, not full piping system representation. STAAD is concerned only with how piping loads act on the supporting structure, rather than with detailed piping components or stress results of the piping system. Therefore piping is represented as a schmatic centerline with anchors, bends, tees, and supports. All other piping components are ignored. This approach allows engineers to independently perform detailed pipe stress analysis in AutoPIPE while ensuring STAAD focuses on its core function—structural load analysis.
Export Model to STAAD Using PipeLink (*.pipelink)
