| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Report |
| Date Logged & Current Version | April. 2018 11.03.00.08 |
What applications can be used to view AutoPIPE's output reports?
After pressing OK button to create an AutoPIPE Input listing report or Output report the program will save the report with the following file extension *.RPT, *.OUT,*.SQI, or *.SQO respectively. These reports are saved to the same folder as the model and will Automatically be displayed in AutoPIPE's Report Viewer (imaged blow):
This report viewer is a very simple application that allows the user to review, search, and print the document. The reports are ascii text file formats that can be opened by any text editor like Notepad, Notepad ++, Wordpad, MS word,Ultraedit, or any other application that can read asicii text files.
