Note: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Bug 1313827 :
ASME B31J: Use of SIF without K Factor
Development Project: 26.00.00
Bug 1711339 :
ASME B31.1 [2020 and later editions] - Building settlement category does not incorporate the bending stresses correctly
Development Project: 25.00.01
Bug 748540:
ASME B31.3 2016 B31J Flexibility modification, Flex = 0.1 - 1.0, crashes the program
Development Project: 12.07.00.346
Bug 748540:
ADO
TFS
Enhancement 1111698:
Add ASME B31.1 2020 edition
Description: Add ASME B31.1 2020 edition, and any associated relevant changes, to AutoPIPE.
Development Project: TBD
Enhancement 936971:
Add ASME B31.1 2018 edition
Description: Add ASME B31.1 2018 edition, and any associated relevant changes, to AutoPIPE.
Development Project: 12.01.00.04
Enhancement 439670:
Add ASME B31.1 2016 edition
Description: Add ASME B31.1 2016 edition, and any associated relevant changes, to AutoPIPE.
Development Project: 11.01.00.07
Defect 139050: Tracker#: 11046
Incorrect equation numbers for ASME B31.1 2010 edition and onward in AutoPIPE V8i 09.05.01.xx and lower
Description: Update the ASME B31.1 2010 and higher code equation reference values.
Workaround: Update to newer version than mentioned below.
Development Project: 09.05.01.05
Enhancement 120729:
Add ASME B31.1 2014 to AutoPIPE
Description: Add ASME B31.1 2014 edition, and any associated relevant changes, to AutoPIPE.
Development Project: 09.06.02.06
Enhancement 73726:
1973 Edition of B31.1 Piping Code addition
Enhancement 138645: Tracker#: 10581
Add B31.1 2012 Edition
Development Project: 09.06.xx.xx
Enhancement 137107: Tracker#: 9313
Update ASME B31.1-2010 material library values
Development Project: T09.04.00.xx
Piping Codes Enhancements & Defects
