Q3. Is the extra StressISO Add-on license required in order to create a Stress Isometric using AutoP
Answer:
No. as mentioned in the AutoPIPE help, a Stress Isometric feature is automatically enabled when AutoPIPE Advanced or Nuclear editions has been selected on the License Configuration / Welcome to AutoPIPE licensing dialog .
However, when using AutoPIPE Standard edition the user will NOT be able to create a stress Isometric. The following will appear:
Again,  no additional license is required. The ability to create a stress isometric using OPIM depends on the edition selected (Standard, Advanced, or Nuclear) during the current session.
Will I incur additional cost/usage when using OPIM?
Can a Stress Isometric be created without an additional OPIM license?
"Bentley OpenPLANT Isometrics Manager not found"... message appears when configuring AutoPIPE Licens
Stress Isometrics - AutoPIPE
How do I download, install, and license AutoPIPE?
