| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | warning message | ||
| Date Logged & Current Version |
Mar. 2015 09.06.01.10 |
The following warning message is located in the model consistency check report:
* * * W A R N I N G - MODEL * * *
W726-14: No anchors in current system
What does it mean and how to avoid?
As mentioned in warning message, the current model does not have an anchor component. If model does not include any fixity, you are experiencing very high stresses and displacements. To stabilize the system and obtain accurate results, you must define at least one fixity or anchor point in the model, which will help achieve the objectives listed below:
Typically, if a model does not have an anchor, it would allow the piping system to rotate about one or more of the 3 global axis (i.e. Global X, Y, or Z) thus resulting in the following Error message being displayed when running an analysis:
Error
E801-1: FATAL ERROR : Unstable system. Need support at node xxx Dir X
OK
However, if a model can be sufficiently restrained on all 3 global axis then no anchor is necessary. The easiest way to tell if a model is sufficiently restrained, run an analysis and see if the E801-1 Fatal Error message appears. If the Error message appears, there are 2 options:
1. Add a support as mentioned in the error message
or
2. Insert an anchor (i.e. Rigid or Flexible).
Note: if your actual as-built system does not include a rigid anchor, consider adding a flexible anchor with very low values for all 6 Translational and Rotational stiffness values.
Warnings Messages displayed in AutoPIPE
