| Version(s): | ALL | ||
| Area: | Warning Message | ||
The following is displayed when using AutoPIPE
Warning
W21-32: Cannot split segments, maximum number of segments reached.
OK
Why does it appear and What should i do now to avoid it?
When inserting / pasting a new segment into the model, AutoPIPE will automatically enter the name of the segment. The default is the next unused letter in the alphabetic sequence. For example, if segments A and B have been previously defined, the default will be C ... Z. The next automatic segment name would be AA - AZ, on up to ZZ for a total of 702 (26x27) unique segment names.
The name entered must be either the default or a deleted segment name. To be sure that no segment names where missed, use "Reorder Segment(s)" command (Home > Operations > Segments > Reorder Segment(s)). Pressing the "Generate Order" button will automatically reorder all segments in the model based on a pre-defined ordering algorithm.(ie. A..Z, AA..ZZ).
