Applies To | |
Product(s): | AutoPIPE |
Version(s): | ALL; |
Area: | Library |
Date Logged & Current Version | July 2021 12.06.00.48 |
Where are the SRC files used to generate a LIB file located in AutoPIPE?
See table below, see version of program that you are using:
AutoPIPE v. 12.x |
File Type |
SRC | C:\Program Files (x86)\Bentley\AutoPIPE CONNECT v12\Libraries |
LIB |
C:\ProgramData\Bentley\AutoPIPE CONNECT v12 |
TAutoPIPE v08.06.00.12 |
Bentley Store |
