The RM Bridge Recalculation Window at the Extended Settings in the Special Settings has one set that allows the user to create additional definitions for the Shear Lag of the specified elements: Use Shear Lag Defs for Stiffness reduct. - Use Shear lag Definitions for Stiffness reductions.
There are two possibilities for setting the program calculations about the element's shear lag:
More technical information is available at the link below, which refers to the specific FAQ document about Shear Lag.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0112484
