PLAXIS Monopile Designer Latest Release notes
New in PLAXIS Monopile Designer 2025.1.3
Release: May 2026
PLAXIS Monopile Designer 2025.1.3 (25.1.3.5) contains the following improvements and updates compared to PLAXIS Monopile Designer 2024.3:
Compatibility with PLAXIS new calculation input and results database
PLAXIS Monopile Designer 2025.1.3 is fully compatible with the new calculation input and results database included in the PLAXIS 3D 2025.1.3 PLAXIS 3D 2025.1.2 and and PLAXIS 3D 2025.1.0.
Other changes and improvements
Fixed issues
A large number of issues have been addressed, including:
Download links
You can update to the latest version using the CONNECTION Client, or download the installer via Bentley System's Software downloads page.
