PLAXIS Output Viewer Latest Release notes
New in PLAXIS 2D/3D Output Viewer 2025.1.3
Release: May 2026
The PLAXIS 2D/3D Output Viewer Version 2025.1.3 contains the following improvements and updates compared to PLAXIS Output Viewer 2024.3:
PLAXIS 2D and 3D Output Viewers are available free to use. The PLAXIS Output Viewer is a standalone application intended for viewing and inspecting the results of a fully calculated PLAXIS model. This application helps you accelerate approvals and reviews by allowing project reviewers, consultants, or clients to provide feedback quickly, without the need to own or use a commercial PLAXIS 2D or PLAXIS 3D license.
New features
File version update
The application is compatible with the following PLAXIS releases:
  • PLAXIS 2D Output Viewer 2025.1.3 can be used for PLAXIS 2D files calculated and saved in PLAXIS 2D 2025.1.0, PLAXIS 2D 2025.1.1, PLAXIS 2D 2025.1.2 and PLAXIS 2D 2025.1.3.
  • PLAXIS 3D Output Viewer 2025.1.3 can be used for PLAXIS 3D files calculated and saved in PLAXIS 3D 2025.1.0, PLAXIS 3D 2025.1.1, PLAXIS 3D 2025.1.2 and PLAXIS 3D 2025.1.3.
Compatibility notes: This PLAXIS 2D/3D Output Viewer can only be used with projects calculated with PLAXIS 2D/3D 2025.1 version.
In order to view projects which are calculated and saved in PLAXIS 2D/3D CONNECT Edition V22.00, V22.01, V22.02, and versions 2023.1, 2023.2, 2024.1, 2024.2 or 2024.3, download the PLAXIS 2D/3D Output Viewer 2024.3 from Bentley System's Software Downloads page below.
Download links
PLAXIS 2D Output Viewer     PLAXIS 3D Output Viewer
