| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 10 June 2024 |
| Date modified | 10 June 2024 |
| Original author | Richard Witasse - Bentley Principal Application Engineer |
Tunnelling in weak rock presents some special challenges to the geotechnical engineer since misjudgements in the design of support systems can lead to under-design and costly failures or over-design and high tunnelling costs. To understand the issues involved in the process of designing support for these tunnels, it is necessary to examine some basic concepts of how a rock mass surrounding a tunnel deforms and how the support system acts to control this deformation.
The stability of tunnels constructed in weak rock is primarily influenced by the ratio of the uniaxial compressive strength of the rock mass to the maximum in situ stress. This ratio is a critical factor in determining the initial support requirements necessary to control strain levels through empirical analysis. While preliminary estimates can be derived from idealized calculations for circular tunnels with isotropic initial stress states, a more reliable approach involves numerical analysis of the tunnel's response to sequential excavation and support installation.
The purpose of this article is to present how PLAXIS could be practically use for this purpose and optimally assess the tunnel behaviour and support associated with the underground excavation of weak rock mass.
Hoek (1999) presented an analysis demonstrating that the ratio of the compressive strength σcm of a rock mass to the in-situ stress p0 can serve as an indicator of potential tunnel squeezing issues. Building on Sakurai's (1983) recommendations, an analysis was conducted to establish the relationship between σcm / p0 and the tunnel's percentage "strain". The percentage strain ε is defined as 100 times the ratio of tunnel closure to tunnel diameter.
Figure 1: Tunnel deformation versus ratio of rock mass strength to in-situ stress
Figure 1 displays the results of a study using closed-form analytical solutions for a circular tunnel in a hydrostatic stress field, as published by Fama (1993) and Carranza-Torres and Fairhurst (1999). The figure shows that the behaviour of these tunnels adheres to a well-defined pattern, accurately predicted by the equation included in the figure.
Figure 1 is valid for the condition of zero support pressure (pi = 0). Similar analyses were run for a range of support pressures versus in situ stress ratios (pi / p0) over the results of which a statistical curve fitting process was used to determine the best fit curves for the generated data for each pi / p0 value. This process finally led to the following equation:
with rp the tunnel sidewall.
The idea of using strain ε as a basis for tunnel design can then be taken a step further by considering the amount of support (pi) required to limit the strain to a specified level as suggested by Sakurai (1983). Typical support pressures for a variety of different systems for a range of tunnel sizes are available in literature especially those of Hoek and Brown (1980) and Brady and Brown (1985) to calculate the capacity of mechanically anchored rockbolts, shotcrete or concrete linings or steel sets for a circular tunnel.
It is important to notice that the previous set of equations for evaluating the tunnel deformation and the extent of the plastic radius are defined as a function of σcm the global rock mass strength! The global rock mass strength is clearly different than the uniaxial compressive strength σc.
The uniaxial compressive strength σc can be derived from the generalized Hoek-Brown criterion usually written as:
where σ′1 and σ′3 are the major and minor principal stresses respectively, σci is the uniaxial compressive strength of the intact rock pieces. Finally, mb, s and α are material constants determined from the GSI rating. Introducing σ′3 = 0 into this equation gives the uniaxial compressive strength of the rock mass as:
In this context, the main challenge is defining the average or "global" rock mass strength as illustrated in Figure 2. The average strength of a rock mass in various structures depends on the degree of confinement, as even minimal confinement can significantly increase rock mass strength due to the Hoek-Brown failure envelope's curvilinear nature at low stress levels.
Calculating average strength is complex due to varying confining stresses, necessitating a compromise solution. One of the most common approaches is to fit an equivalent Mohr-Failure envelope to the failure. This can be done using a solution published by Balmer (1952) in which the normal and shear stresses σn and τ are expressed in terms of the corresponding principal stresses σ′1 and σ′3 and then calculate the average cohesion ceq and friction angle φeq values by linear regression analysis, in which the best fitting straight line is calculated for a relevant range of (σn , τ) pairs. The uniaxial compressive strength of a rock mass is finally defined by a cohesive strength ceq and a friction angle φeq is given by:
The actual process of curve fitting has been discussed in detail in Hoek, Carranza-Torres and Corkum (2002) and the following relationship between the global rock mass strength σcm and the Hoek Brown parameters has finally been proposed:
Empirical methods are useful for initial estimates of support pressure needed to limit plastic zone size or tunnel closure. However, these methods often fall short for practical applications, requiring a detailed numerical analysis to assess more accurately tunnel closure and plastic zone but also to optimize the rock support interaction.
Critical mechanical properties of the rock mass, such as compressive strength σcm, angle of friction φ, modulus of deformation E, and initial state of stresses, must be assessed in the first place. Classification systems like the Geological Strength Index (GSI), Q-system, and Rock Mass Rating (RMR) are commonly employed for these estimations. Hoek-Brown failure criterion is often used for the assessment of the rock strength.
PLAXIS software provides valuable constitutive models with that respect:
Defining the geometry and initial stress conditions accurately is crucial. Complex tunnel shape can easily be defined through the PLAXIS Tunnel Designer. One should first make sure the model dimensions are sufficiently large compared to the tunnel dimensions to prevent any boundary effects (see Figure 3).
Initial vertical stress is calculated based on the weight of the overburden rock, while horizontal stresses are defined from stress ratios with the possible consideration of locked-in stress. Two relevant methods in PLAXIS for evaluating in-situ stresses are the K0-procedure and the field stress method.
Estimating support capacity can be guided by published equations from Hoek and Brown (1980) and Brady and Brown (1985). These equations calculate the capacity of various supports, including mechanically anchored rockbolts, shotcrete, concrete linings, and steel sets. Although care must be taken when applying these idealized calculations to real-world problems, they can still be considered to be representative of the tunnel support as a first approximation for the evaluation of tunnel closure and plastic zone.
Figure 3: Geometry Definition
Non-associated plasticity in numerical simulations can lead to convergence issues which are characterized by non-uniqueness of the numerical solution, sensitivity to perturbations, and discontinuous responses.
This could be particularly pronounced when using the Hoek-Brown model with large plastic strain development (i.e. poor rock conditions and/or low compressive-strength-to-initial-stress ratio). Indeed, the very high level of non-associativity induced by the Hoek-Brown criterion at very low stress confinement level (difference between the friction angle that corresponds to the tangent of the HB criterion and the dilatancy angle which is 0 by default in PLAXIS HB model) will significantly affect the convergence rate and lead to lightly premature termination of the PLAXIS calculation.
Their main characteristics are the development of localized shear bands, around the excavated area along with repetitive sequences of unloading steps (as an attempt to overcome local numerical instabilities and therefore considerably lowering the convergence rate) although each numerical step manages to fulfill all convergence criteria (See Figure 4). Usually, the finer the mesh or the highest the element order used, the more pronounced the convergence issues will be.
Strategies to address these issues include:
Indeed, extremely low compressive strength values associated with GSI may not accurately represent the true strength and global mechanical behaviour of the rock mass in an average sense at the scale of the RVE (representative volume element) for the considered tunnel analysis. Using an equivalent Mohr-Coulomb model might provide a more representative depiction in poor conditions.
| (a) Incremental shear strain |
(b) Convergence log
Figure 4: Main characteristics of the non-convergence behaviour
Figure 5: Rock uniaxial compressive strength as a function of GSI
Although the consideration of an equivalent support pressure is often useful for the evaluation of the tunnel closure and the extent of the plastic zone, detailed structural member analysis of tunnel support might be required either for a more accurate representation of the support action onto the excavated rock mass or because structural analysis for the support system design is required.
PLAXIS is a powerful tool for detailed tunnel support modelling. It allows for the simulation of different support systems and their interaction with the rock mass.
Tunnel excavation support, which may be steel sets, rockbolts or shotcrete or some combination of these, is installed some distance behind the tunnel advancing front. It acts like a spring and the support action that it provides to the tunnel increases with convergence of the tunnel.
Shotcrete can be modelled as a plate element or volume element, which are interacting with the rock mass through interface elements as shown in Figure 6.
Figure 6: Shotcrete modelling in PLAXIS
Steel sets are typically used in combination with shotcrete and can be modelled either as individual beam elements (option only possible in PLAXIS 3D) as shown in or using a homogenization approach consisting in defining a composite plate the properties of which are calculated by averaging the contribution of the shotcrete and spaced steel sets (equivalent section).
Figure 7: Spaced steel set modelling (pink beam elements) in PLAXIS 3D
The equivalent stiffnesses of the composite plate is obtained by summing the rigidity of shotcrete and steel sets:
with
where:
Once and
have been computed, equivalent thickness and equivalent Young's modulus can be evaluated as:
and
Once structural forces are being calculated for the composite plate, it is possible to redistribute these thrusts and moments back onto the individual support elements. The equations for the redistribution of the moment Meq, axial thrust Neq and shear forces Qeq induced in any one of the beam elements representing the equivalent shell are (thin beam solution only):
| For shotcrete: | For steel sets: |
Rockbolts and cables are represented as cable elements in PLAXIS, suitable for various types of bolts and cables. Cable elements can interact with rock through bond element allowing for skin friction development (see Figure 8). The cable can support a normal force up to user-defined maximum values (in both compression and tension) at which it will behave plastically. The skin friction (at the cable/grout interface or at the grout/rock interface) can also be made dependent on the effective confining stress:
where is the grout cohesive strength,
the grout friction angle, and p is the grout exposed perimeter.
Figure 8: Cable element formulation
In tunnel construction, ensuring face stability is crucial to prevent collapses and provide safe working conditions. Various methods can be employed to address face instability, depending on the geological conditions, tunnel depth, and specific project requirements.
Figure 9: Modelling fiberglass dowels in PLAXIS 3D
A very common method to protect the rock core ahead of the face, consists in using grouted fiberglass dowels. In PLAXIS, these can be modelled using cable elements (see Figure 9), although an equivalent stabilizing front pressure is often applied to the excavation face for practical purpose. Indeed, the detailed analysis of the grouted fiberglass dowels and their interaction with surrounding rock could be quite cumbersome. Considering that their purpose is to stabilize the tunnel front face and that they are progressively removed as the tunnel front advances, an equivalent stabilizing front pressure as suggested by Peila (1994) is often preferred from a numerical modelling perspective:
where:
During tunnel construction, sections with challenging ground conditions, such as high-water inflow or unstable fractured rock, can significantly impact face stability. In such cases, it may be necessary to stabilize and seal the section to be excavated using forepoling techniques like pipe roofing. This method involves driving poles, timber, or steel tubes into the ground before excavation. In PLAXIS, this technique can be modelled using embedded beam elements. The geometrical representation of these elements in PLAXIS 3D is simplified through the tunnel designer, allowing convenient definition from the theoretical excavation shape (corresponding to the tunnel crown), including their spacing, length, and angle (see Figure 9).
Figure 9: Modelling forepoles pipes in PLAXIS 3D
Excavating tunnels in weak rock presents significant engineering challenges due to the inherent instability and potential for large deformations. These difficulties necessitate a comprehensive approach that combines empirical methods and advanced numerical modelling techniques to ensure safety and structural integrity.
The article highlights the importance of utilizing PLAXIS for detailed simulation of tunnel support systems. PLAXIS allows for precise modelling of various supports, including shotcrete, steel sets, rockbolts, and fiberglass dowels amongst others. These elements are crucial for stabilizing the tunnel face and controlling deformation during excavation. The use of plate, cable and embedded beam elements along with the tunnel designer feature in PLAXIS 3D facilitates accurate representation and efficient design of tunnel support systems.
Empirical methods, such as those developed by Hoek and Sakurai, provide valuable insights into the behaviour of tunnels in weak rock. These methods help predict ground response and support requirements, forming a basis for initial design considerations. However, the integration of numerical modelling is essential for refining these predictions and addressing complex geological conditions.
Numerical modelling is particularly valuable for designing tunnels in weak rock because it enables a detailed analysis of ground behaviour and support interaction. Through simulations, engineers can evaluate various support configurations and their effectiveness in real-time, allowing for optimization before actual construction begins. This predictive capability helps in anticipating potential issues and adapting the design accordingly, ensuring that the chosen support systems can handle the expected loads and deformations. By using PLAXIS, engineers can create a more robust and resilient tunnel design, minimizing risks and enhancing the overall safety and stability of the project.
In conclusion, the successful excavation of tunnels in weak rock relies on a multidisciplinary approach that integrates empirical analysis, numerical modelling, and practical support methods. This approach not only enhances the safety and stability of the excavation but also optimizes the efficiency and effectiveness of the support systems. By leveraging advanced tools like PLAXIS and implementing robust support strategies, engineers can achieve the structural integrity necessary for safe and successful tunnel construction in challenging geological environments.
