| Version: | All | ||
| Area: | General | ||
| Subarea: | N/A |
What is the dmsg activatetoolbypath key-in?
This key-in is part of a group of older key-ins that were more primarily used in archived versions of MicroStation.
It will activate a tool, task, or other resource via its direct path within a .dgnlib file.
Key-ins like this are handy when composing MDL or VBA and creating general automation for tasks.
Here is an example key-in that parses the delivered V8iTasks.dgnlib for a specific command:
DMSG ACTIVATETOOLBYPATH \Drawing Composition\Organize\Add a Link to an Element
Here is the exact command in the heirarchy tree (within Customize dialog):
Using this key-in will activate the Add Link to Element tool:
