Updates to Support In-Take Form
A guide to provide information on updates to the product support In-take form.
On January 25th, the support in-take form on Bentley Support Portal was updated. This update ensures that the form will now capture requests for hosted Bentley products, AssetWise or ProjectWise. It will allow you to submit all the necessary information when filling out the in-take form, ultimately helping us to process your request faster. The short Q&A below provides a quick overview of this update.
What has changed?
New options will now appear when you select 'Request in the Category Field if your query is related to ProjectWise or an AssetWise product hosted by Bentley.
For AssetWise requests, what has been updated?
For AssetWise, you will now be able to select new types of requests regarding MAS options, including:
For ProjectWise requests, what has been updated?
For ProjectWise, you will now be able to select new types of requests regarding MAS options, including:
What happens after I select one of the new request types?
New mandatory fields will also appear when one of these values is selected. We encourage you to provide the requested additional information so we can proceed to process your request.
Bentley is dedicated to improving your support experience, and we have made these updates to ensure prompt resolution when you submit a request for a hosted AssetWise or ProjectWise product.
