To access your EasyPower license, you will need to use the Feature Level Selector when installing the program. After downloading EasyPower 2025:
Note: you should only need to make this selection one time, unless you need to change active licenses.
Account Administrators will need to contact their Enterprise Success Manager or their Account Manager to have their EasyPower license(s) added to their E365 program.
You need to first be logged in to the Bentley Connection Client, then click on the Windows Start button and search for EasyPower (or EasyPower Demo, if you have the demo version).
Yes, you can have multiple versions of EasyPower on the same machine. For example, if you already have EasyPower 11.0, you can also install EasyPower 2025 without overwriting 11.0. The new version will be installed in a new program folder.
EasyPower can be installed on either a local or network drive, regardless of whether the local or network version is purchased. Also, EasyPower does not require you to save your data files in the same directory as where EasyPower is installed. Therefore, you can install EasyPower on a local drive, but save your data files on a network drive that is backed up. The program itself does not need to be backed up since it can always be reinstalled. This is now considered a legacy licensing solution and not used unless necessary.
Yes. You will need to do a full install on every user machine. When you do the setup for each user machine, you will need to specify the IP address of the machine that has the license manager and the hardware key. This is now considered a legacy licensing solution and not used unless necassary.
The default folder for EasyPower is C:\ProgramData\EasyPower\EasyPower. You can choose a different folder during installation.
EasyPower’s main physical security mechanism is a hardware key, available for a parallel port or USB port. EasyPower can be installed on multiple machines; however, the hardware key must be plugged into the machine currently using EasyPower. This maintains the single-user status. This is now considered a legacy licensing solution and not used unless necessary.
