Design Speed Optimization Eurocode
The improved Algorithm enables OpenTower Designer to perform Structural Analysis and Design in a 30 % lesser amount of time.
Analysis Speed Optimization for Tapered Monopole
A massive improvement in the algorithm which helps a substantial reduction in the time taken for the Tapered Monopole Analysis
Optimization in Scenario Activation and File Opening
Improvements are made in the performance during File Opening and Scenario Activation.
The new algorithm enables us to complete the operation in about 30 % less time when compared to the earlier version.
Improvement of messaging during several processes
There was a review of some of the output messages provided by OpenTower during the structural analysis procedure:
Visualization and Design Methodology Improvement for Asymmetric Sections
The orientation of asymmetric sections is an important subject in structural design, affecting loading and utilization. OpenTower Designer counts now on different tools to allow the user to define such properties:
This affects the performance of member design as the local axis changes according to local orientation.
Ancillary Import from any twr file
One of the limitations of the earlier version of the OpenTower is not having the facility to import a twr file multiple times in an OpenTower Model. Also, according to the user's recommendation, wind loading and terrain information could not always be needed.
The recent version of the software is equipped with a tool through which you can import twr-file equipment as many times as you like.
The tool only brings the Appurtenance information (both Large and Linear)
Spreadsheet Interoperability for the Large Ancillaries
After considering customers internal procedures, there was need for an easy and quick way to feed OpenTower Designer with large ancillaries.
A new facility is provided by which Large Appurtenances data can be exported to or imported from a straightforward spreadsheet. This spreadsheet can be generated by the user and be loaded in any Appurtenance group which will allow the user to build scenarios depending on customer desires. Furthermore, this tool will help to obtain progressive records of equipment status and corresponding utilization.
As shown below the user has an option to choose between Absolute Azimuth or Relative Azimuth during the import depending on the reference system used in internal records.
During the import mechanism, the appurtenances in the spreadsheet are appended with the current set of records.
You can export the Existing Appurtenance group in a new Spreadsheet and use that as a template for further modification.
Post-processing Data for Euro code
Until now, there were some limitations in the applicability of Eurocode in OTD. It was certainly difficult to gusted forces and corresponding results.
The structures that are analyzed with Euro code will have a separate table and graph to interpret the design forces and results in the Tower Model Explorer. See below figure.
Those new utilities will be available after performing Member Design of whole structure where GEN factor is considered in the results.
The following features are available.
In addition to that, there is a new specific command to have the designed forces used while performing the Eurocode checks during the Member Design. This will be printed as EuroForcesData.csv into the OTD file directory showing Axial, Shear and Bending forcing in local axis for all Load Combinations in each members sections.
The printing of all that data may have an impact on time performance as a result of, by default, the option being turned off. To activate it you can set the configuration file as bellowed figure. The configuration file is located here.
"C:\Users\Credential\AppData\Roaming\Bentley\Engineering\OpenTower\Configurations\TowerConfig.xml"
Reaction GEN in a CSV file
To allow foundation assessment with gusted forces, the reactions for all Load Combinations are not reported in CSV format in the same directory where the Tower file is saved as <<TowerName>>SupportReactionGen.csv.
Ancillary Rotation in a CSV file
To assess the antenna-service-performance requirement contained in some National codes and owner's design rules, OTD counts on this report which provides rotation of the structure at each corresponding ancillary location.
The Ancillary Rotation is now reported in a CSV format in the same directory where the Tower file is saved as <<TowerName>>AncillaryRotation.csv
The values are correlated from the deflected values induced by design forces on all load combiantions.
Rooftop Tower Analysis
OpenTower Designer is now able to perform Analysis and Design of rooftop structures which are modelled as a Single UDP panel in MStower. Taking advantage of the Mount Frame Analysis Engine the software can do a SA of the model imported from MStower. The same solution can also be used for reinforcement Monopole.
The Analysis is performed according to TIA 222H.
Once you activate a scenario, click the “Analyse Model” Button in the TOP Menu Bar for Structural Analysis and Design.
Eurocode Report
For Eurocode a curated Report format is designed to show the governing Load Case.
The Report is Categorized in the following items.
NOTE: The Load Cases of more than 1000 are internal load cases created as a part of the Secondary Truss Analysis. For others, they referred to the Combination Load case number.
Rooftop Report
A Separate Report Node is created for the Rooftop Structure.
OTD – OTiQ Integration
OTD – OtiQ integration is enhanced in this version. Not only in the interoperability feature but also in the drawing generation and equipment loading page where the Geographical North direction and annotation of legs and faces are made consistent with OTD convention.
