To access project information such as Folders or Files, users will use the Document module on the left panel. Files and Folders can be stored and accessed in the Documents default storage or a Work Area Connection to a specific Work Area in a ProjectWise Design Integration instance.
Any image added to a folder in the default Documents storage or to any Form will show in Media Explorer
Components added to the Enterprise Component Center Catalogs can be shared with any project. Shared components will show in the Components tab
