December 2023
Reality Data such as Point clouds, Reality Meshes, OrthoImages, etc can now be associated to a ProjectWise Powered by iTwin project and turned on/off in any iModel
To learn more on how to Manage Reality Data in ProjectWise Powered by iTwin - click here
To learn more about Reality Modeling, Reality Data and how to Optimize & Upload Reality Data to iTwin - click here
When hovering over the lower part of the iModel image tile, a highlighted band labelled "Show saved views" will appear:
Click on this band to open a sub-panel with a list of saved views for that iModel
Click on the desired Saved View to open the iModel
To learn more about iModel Manager click here.
November 2023
Now you can Export to IFC a Saved View instead of all the iModel.
Simply turn on Saved Views and select the desired View from the drop down.
To learn more about Export to IFC click here
Settings per connection can now be accessed via the gear icon on the connection toolbar:
Or by access the 3-dot menu on the connection row:
For more information refer to Connections Settings here.
October 2023
A new datacenter, located in the European Union, is now available when Registering a Project in Bentley Infrastructure Cloud
The Media Explorer lets the user index and search through potentially thousands of photos/videos which can be added to a project through any form, like Issues as well as uploading them to any folder.
Most photos and videos are not organized and maybe on employee devices, making them difficult if not impossible to find and retrieve in the event of a claim or other need.
The Media is uploaded and stored in a central location. When the project needs access to that Media for any purpose, time is not spent trying to find media all over the place.
To learn more about Media Explorer click here
Project Owner role can be assigned to one or more project participants. This will allow IMS Admins to delegate Project Administration tasks.
Participants must have ProjectWise Validate entitlement to be assigned as Project Owner
For details on how to Assign Project Owner click here
IFC Export has been added to the Context menu in iModel Manager.
This allows a user to export to a specific supported version of IFC and save it to a location on the Infrastructure Cloud project's documents areas. This can be in the Documents area, as well as any valid Work Area Connection location.
This also allows for configuring IFC class mapping using .json files. The structure of the mapping files is explained in detail here:
To learn more about Export to IFC, click here
September 2023
A new permission has been made available which gives a user the ability to create a project without needing full administrative privileges. The Create New iTwin permission, when coupled with the Reprovision Project from a Template permission, allows administrators to assign project creation rights to a role without giving administrator privileges to that role.
These roles are set in the Enterprise Role Management section in the Connect portal.
For details on managing Roles and Permissions Click Here.
A new tag showing which projects belong to external organizations, has been added to each project's tile and header
This will provide better understanding on which projects belong to your organization and which are from another.
August 1st, 2023
The Administration tool can now be found at the bottom of the left navigation bar.
July 25, 2023
Custom Forms Creation is now available in ProjectWise powered by iTwin. This will allow users to create their own forms for each project.
There are several Form Types and Templates to choose from.
To learn how to Create Forms or Modify existing ones - Learn more
May 5, 2023
The Project Dashboard gives you an overview of the project's performance. By Type, you can filter by Issue, Document Review and Design Task.
The forms are also organized by statuses: Approved, Assigned, In review, Rejected.
In addition, you may view all forms separately in a table view if you need to act independently on each form.
