Deliverables
ProjectWise Deliverables Management provides secure deliverables exchange between business entities. It ensures that deliverables package information can be trusted, speeds up preparation process, and makes it easy to identify and resolve urgent issues.
Key benefits:
Available Package Types
Transmittals / SubmittalsRFIsGeneral Correspondences
Used for design deliverables review and approval:
  • when you need to review multiple documents and send a separate response for each document
  • each document can be responded to by multiple reviewers from different organizations
  • ability to review and markup PDFs through a web browser (PDF Markup Service)
  • multiple reviewers from the same organization can markup the same PDF at the same time and see each other's comments and issues as soon as they are made
  • helps resend new document versions with fixes
Used for formal Requests for Information (RFIs):
  • single response per package from single RFI recipient (cc recipients are kept in the loop but cannot respond)
  • no ability to respond per each attached document
  • multiple response cycles supported until response is accepted
  • ability to suggest and finalize impact to help negotiate scope
Used for all other contractual communication:
  • manage and track all contractual communication using a single tool
  • multiple responders supported per package - cc recipients can also respond
  • threaded view to see multiple related packages and their responses in a single page
  • helps track "ball-in-court" responsibility
  • better than email: custom form with configurable attributes; response due dates and reminders, audit trail
