Prerequisites
Entitlements
ProjectWise powered by iTwin uses three different entitlements.
ProjectWise Manage
ProjectWise Engineer
(All features of ProjectWise Manage, plus)
ProjectWise Validate
(All features of ProjectWise Engineer, plus)
Assign Entitlements
To check if the organization has ProjectWise Manage, ProjectWise Engineer and ProjectWise Validate entitlements enabled, go to Connect.bentley.com, select Entitlement / License Management.
and select the organization’s subscription.
Filter the Application portfolio to find the entitlements.
By default, all users in the organization are allowed to all entitlements.
Default Access can be modified to Deny. If this is the case, no one in the organization will have access to the entitlement, and it should be assigned per users’ base.
To block or allow the use of an entitlement, click on Create Exception an select Users.
Type in the user’s name and click on the button
Learn more about Entitlements
