Hovering over the bottom-right corner of the an iModel tile will display a "3-dot" context menu. Clicking on this icon will display options for interacting with the iModel. The menu options will differ depending on whether the target is a "Connected iModel" (synchronised with Connectors), a Composite iModel (iModels from iModels) or an iModel created from a SYNCHRO Pro .SP file. The options are: |
Connected iModels |
Composite iModels |
These iModels have the "Composite" tag\badge displayed in the iModel tile image The context menu for Compsite iModels is essentially the same as for Connected iModels, with two exceptions:
iModels from SYNCHRO .SP files |
These iModels have the "4D" tag\badge displayed in the iModel tile image.
The context menu for 4D iModels is essentially the same as for Connected iModels, with the exception of an additional entry to download the .SP file. For information on SYNCHRO-specifc iModels refer to the KB articles here. |
