Home Page Layout
When working inside a Project, the Home Page is divided into three main parts:
Modules (the Sidebar)
All the Modules available in ProjectWise powered by iTwin are displayed and accessible from the widgets on the sidebar.
The Home module is where you would land most of the time when you enter a project. This view gives an overview of the project and your usage. The displayed content includes Weather, Recent activity, My work, Create, iModels, and Summary.
Top Bar
The top bar contains the following options:
Project name and weather
This area contains the basic info of your project with its name and weather info.
  1. Project Name - When selected, it will redirect the user to the Edit Project
  2. Favorite - Select the star to add this project to your favorites.
  3. Date and Weather - Denotes today’s date and weather. It will automatically be populated during the project provisioning based on the latitude and longitude coordinates of the project.
    The Temperature Measurement (Fahrenheit and Celsius) is linked to the localization settings in the user’s browser. To change this setting, refer to the default browser’s localization settings help documentation.
    Note: If the weather is missing or not set to the correct location, contact your project admin or refer to this wiki for details on registering the project location.
My Recent Activity and My Work
My Recent Activity gives quick views of all recent activities performed by the users including Design Task, Issues, Document Revies, etc, essentially the items that you have viewed.
My Work displays all the work items assigned to the logged-in user. If the work items have been given a Due Date, it will be shown under the title. To the right of the due date, it will identify how many days are left until it's due. Any overdue tasks are tagged in red   to get immediate attention.
Note that at the bottom of My work – View all, this link will open the Work Module, which will be explained in the next chapter.
Create
Create is a quick link to create work items such as Document Review, Design Issue, Design Task or any other custom form
iModels
The iModel section allows quick access to any iModel that has been added to the project. You can select the left and right arrow to toggle through all the iModels. You can open the iModel in the iModel Viewer page by choosing the iModel.
Summary
The project Summary section displays the quick statistics of the project. For speedier information access, it’s divided into My work and Project.
My work displays a summary of the logged-in users’ work items. Identifying how many of each type of form in what statuses. The Project section, on the other hand, displays the overall project summary.
