Register a Design Project
OR
Belong to an RBAC Enterprise Role that has Provision a Project from template and Create new iTwin rights enabled.
Learn more about RBAC Enterprise Roles and Permissions
  • Fill in all the required fields such as Project number, Project name, and Billing country
  • Remember to select the desired Data center location as it cannot be modified in the future.
  • Enable Media Indexing is on by default. So each image you upload to the Documents storage or attach to a Form will show in Media Explorer.
  • Project image and Project location can be filled in as well or modified after project creation.
  • Click Next to continue.
  • Select the project template to be used to register the new project.
  • If this is the first Design project registered in infrastructurecloud.bentley.com, select Bentley project template and Standard ProjectWise Template.
Projects can then be identified as Organization project templates and be used to register other projects.
  • Click on Register to start the process
  • Once finished, click on Done.
