The following provides a walkthrough of creating a sample Form, with links containing further information for each stages.
Note: If the Manage Form option is not visible in the Administration settings, you will need to contact your project Admin to grant you access.
Asset Inspection |
Deficiency |
Memo |
Risk |
Civil design |
Design |
Observation |
Site Observation |
Clash |
Field data |
Other |
Submittal |
Closeout |
General Correspondence |
Punchlist |
Site Inspection |
Communication |
Issue |
Review |
Task |
Daily Log |
Meeting Minutes |
RFI |
Create New Type |
Note: The form type acts as a container for the workflow. Workflows are configured per form type. All forms of the same type will follow the same workflow.
Since it does not have a workflow defined yet, click Import Workflow Template to import an existing workflow.
Select the Review Workflow option and click the Import button.
The Review Workflow is loaded into the form. .
