Set Workflow
Workflow allows users to generate a form where multiple team members can participate in filling it out. The workflow permits users to control what parts of the form each team member can view or edit.
Note: Workflows are configured per Form Type. If you have multiple forms of the same type, they will follow the same workflows.
Creating the Workflow Structure
Workflow Options and Settings
Multiple Approvals
