This tool creates a profile along a drainage network based on a user-selected range of structures.
Within the Civil Front Stage, select the Profile icon, then select the Drainage Profile tool from the menu.
After clicking the tool, follow the prompts in the lower left corner of the screen and select the reach/drainage structure you wish to the be the start of the drainage profile.
After selecting the initial reach/structure, select the 2nd structure which will be the ending of the drainage profile. After selecting the 2nd structure, click in space to accept the reach.
The drainage profile will open.
To change the structure annotation display, go to Annotation Options in the top right corner of the profile view.
