Validation Summary
The summary contains the results of each of the various validations and analyses that have been completed within the project model.
Finding the command
In the Civil Frontstage, open the left widget panel and select the Civil Design Validation and Analysis tab.
After selecting the Civil Validation and Analysis widget, click the drop-down menu to access the Summary.
Review Validation and Analyses
The Summary works like the results panel of each of validations and analyses. The summary can be navigated by expanding each heading and browsing thru each section of the results. The display of results can be controlled by clicking the eye icon.
