Civil Quantity Area
This command provides a summation of a group of mesh elements contained within a fenced area.  The Top Slope Area, Planar Area, and Volume are displayed in a measurement tabbed view.
Finding the command
 [Note: This command will only be active if a Civil schema is detected in the iModel]
Open the Civil Tools icon from the Default Frontstage main toolbar and select the Compute Quantity Area icon. Or from the Civil Frontstage, open the Quantity icon and select Compute Quantity Area.
Compute Quantity Area Execution
You will be prompted to Enter the first point of the rectangular area you to create. After clicking to begin the placement of the area, you will be prompted to Enter the second point. Click again to define the extent of the rectangular area. The summation of all the elements contained in the area is displayed in the right panel under Measurements.
Please refer to this video for visual presentation:
https://youtu.be/H775lNdiDoo
