Civil Reports - Quantity Reports – Along Alignment
This command produces a report on the quantities using elements located along an alignment.  (Only visible elements will be taken into account)
Finding the command
Civil Reports can be found in a separate docking tab.  These tabs can be relocated all over the user interface.  In the quantity reports select “Along Alignment”, the plus sign appears for “New Report”.  You can also manage the reports into folders by selecting the “Add New Folder” button.
‘Along Alignment’ Selection Tool Settings
Once the command is executed the tool settings will appear along with the following prompts:
The “Left Offset” and “Right Offset” allow you to define the buffer width for the element selection.
Report
Once the report generation is complete, select the arrow to show the report expanded view.  This view will provide two button options, “Download the Report” which creates a .csv file for use with applications such as Excel, and “Open the Report in a New Window” which displays the report in HTML in a new browser window.
Please refer to this video for details:
https://youtu.be/vn20vwcE-XM
