Unified Forms iModel
The New Forms Widget can be docked in different locations and its presentation will change.  While docked at the top or bottom of the model view it will present as a table.  Every column can be sorted and filtered.  If docked on the side, it will change to more of a compact card display but all the same information is contained and can be filtered.   Filters can be saved and recalled.  The forms are filtered by the model you are viewing.  The form not associated with the model you are in will not be shown unless you choose the "Show All Forms of Project"
