The below information will take you through the updates that are specific to this application. For more general information and product update videos, please see the general New Release page.
10.0.2.1637
Released 12th October 2026
- Fixed a bug where renaming template either from lower to upper or vice versa would not re save the studio document so wouldnt appear in template list.
10.0.2.1637
Released 5th October 2026
- Fixed an issue that prevented opening tables within templates in laboratory configuration packs.
10.0.2.1626
Released 28th July 2026
- Fixed an issue that prevented the app from opening after a recent update.
- Added positioning tab to description bar for styling continuation text and end of borehole text so text can be repositioned.
10.0.2.1616
Released 20th July 2026
10.0.2.1607
Released 27th May 2026
- Updated pdf viewer.
- Security updates.
10.0.1.2551
Released 4th March 2026
- Added dynamic scale to barchart library items.
10.0.1.2549
Released 23rd February 2026
- Our charting engine can now draw multiple lines in an expression series when a group is set. A line is created per entry in the specified group.
10.0.1.2544
Released 3rd February 2026
- Our charting engine can now natively support circular data series, allowing for example for Mohr's circles to be generated and visualized.
10.0.1.2530
Released 6th October 2025
- Bug fix where templates would break when changing Short Display Name
10.0.1.2515
Released 22nd September 2025
- Added checkbox option to omit blank page transition for dynamic logs
10.0.1.2512
Released 9th September 2025
- Fixed a bug where Project Sheets with Page By option set were not visible in the list of templates
v10.0.1.2507
Released 8th September 2025
v10.0.1.2499
Released 14th August 2025
v10.0.1.2461
Released 3rd May 2025
- Bug fix to prevent crashing on preview when row count is invalid
v10.0.1.2455
Released 29th April 2025
- Added unit support for vertical scale library item.
- Can set different units for the scale default behaviour is not set.
- Fixed bug for expressions on tables where there were some issues with using aggregate expressions in tables
v10.0.1.2453
Released 22nd April 2025
- Minor improvements to quick section generation
- Fixed rounding issues with row table heights and fixing row widths
- Fixed issues with charts and tables not showing correct series
v10.0.1.2447
Released 1st April 2025
- Added new "repeat on new page" for range data text items on dynamic logs
- Bug fix for rotated text range items which would never centre align
v10.0.1.2430
Released 19th March 2025
- fixed a bug with legacy range data text items not being shown in correct posistion
- added legacy tag to show that this range data text item is a legacy item compared to the new range data text.
v10.0.1.2423
Released 11th March 2025
- Bug fixed for token refresh where it signed user out and crashed when attempted to sign back in
v10.0.1.2419
Released 10th March 2025
- Added enhanced support for point data text and range data text so each item can be individually styled
- Added new boundary library item
v10.0.1.2386
Released 21st January 2025
- Option added in Template Setup dialog to group data by a model group used in tables on templates.
v10.0.1.2381
Released 9th January 2025
- Added enhanced support for vertical scale bar library item metric and imperial.
v10.0.1.2379
Released 12th December 2024
- Added enhanced dynamic log support
v10.0.1.2376
Released 10th December 2024
- Fixed a bug where some projects took a long time to open
v10.0.1.2369
- Improved use true font size option so font sizes are more consistent
v10.0.1.2363
Released 25th November 2024
- Added improvements to table library item which includes
- Ability to set row height. Row height will increase beyond set amount if text is too large
- added fixed row height option which will shrink text to fit exact row height specified
- Added horizontal line, continuing line and closing line options.
v10.0.1.2357
Released 19th November 2024
- When creating or editing a graph on strips or borehole logs:
- For line graphs the override symbol label and dropdown are now disabled.
- For scatter graphs and connector bars, these options remain enabled.
v10.0.1.2353
Released 14th November 2024
- Bar Chart and Graph elements can now be created also for groups that have a depth field.
v10.0.1.2344
Released 13th November 2024
- Fixed a bug where logs wouldn't preview as claim missing group from configuration
- Fixed a bug where unable to edit tables field expressions in certain circumstances
v10.0.1.2334
Released 7th November 2024
- Added the ability to set row height on tables
v10.0.1.2331
Released 5th November 2024
- Functionality has been added to display symbols from symbol sets in tables for the data shown.
v10.0.1.2318
Released 4th November 2024
- Added the option to Use True Font Sizes in the Template Setup dialog that would impact the following library items: Bar Chart, Description Bar, Graph, Image Grid, Site Plan Legend, Table and Vertical Scale (More Information)
v10.0.1.2305
Released 28th October 2024
- The default value for Repeat Mode property for new tables on Header Sheets and Project Sheets is now set to Do Not Repeat
- Enhancement to sections to allow the user to control the Strip Area grid and ticks increments with an expression
- Data series Name for charts is no longer automatically added to the Chart Legend
v10.0.1.2295
Released 15th October 2024
- App security update
- Added style option for bar charts
v10.0.1.2231
Released 04th September 2024
- Added drop down for dataset group drop down in the charts dialog. This enables display of data and legend blocks to group by parent and it own groups key fields
v10.0.1.2185
Released 31st July 2024
- Enhancement to sections to allow the user to display chainage or offset on a Strip through the use of expressions
v10.0.1.2174
Released 19th June 2024
- Fixed a bug where the app would crash when a Column (x) was not set in the Graph Editor
- Added the ability to set centre strip column for Section templates and the ability to hide strip columns for sections only
v10.0.1.2163
Released 6th June 2024
- Added new Strip Profile functionality to Studio
v10.0.1.2157
Released 24th May 2024
- Bug fix for Studio crash when table header does not have a group header associated with it.
v10.0.1.2135
Released 14th May 2024
- A popup dialog has been added to prompt users to confirm or cancel saving any changes made in the Master Strip Set dialog.
v10.0.1.2129
Released 2nd May 2024
- Fixed a bug where template file couldn't be opened if it was saved using a different local numeric formatting.
v10.0.1.2124
Released 30th April 2024
- Fixed a bug where one bar chart column would be shown over all the columns and was not confined to its designated column.
- An issue was fixed where the app would crash when trying to use a filter group in a strip that referenced a non-existent group.
v10.0.1.2103
Released 23rd April 2024
- Improved the app to prevent crashing when opening the Filter Group dialog due to the filters referencing non-existent groups or headers
- Fixed a bug where the it was not possible to enter a valid number value for a filter
v10.0.1.2091
Released 18th April 2024
- Added an autosave feature where a template will be saved locally upon opening the template and then changes will be saved ever 10 minutes
- Fixed an issue where changes in TextBox Properties tab were not saved
- Fixed an issue where GPU Cache and DawnCache folders were created on Desktop instead of the appropriate Local App Data folder
v10.0.1.2082
Released 16th April 2024
- Fixed an issue where adding new document category options wouldn't show in Studio
v10.0.1.2071
Released 27th March 2024
- General app stability update
v10.0.1.2065
Released 25th March 2024
- Bug fix for where user with invalid user permissions was able to edit strip sets
v10.0.1.2025
Released 05th March 2024
- New Feature Smart Pointers added
- Report Options units per page expression support added
- Bug Fix: App crash when bar chart dialog is selected
v10.0.1.1988
Released 9th February 2024
- removed associated location headers from civil sections for data label text as not required.
v10.0.1.1973
Released 22nd January 2022
- Updated to newer Telerik controls build which should prevent template corruption from happening.
- Enabled adding of dynamic legend to sections
v10.0.1.1937
Released 12th January 2024
v10.0.1.1922
Released 15th December 2023
- Security update for application
v10.0.1.1915
Released 12th December 2023
- Fixed a bug where it was not possible to add decimals to fields in the UI
v10.0.1.1909
Released 6th November 2023
- Updated the User Guide link as well as the order of the help icons
v10.0.1.1904
Released 5th December 2023
- Fixed a bug where the point data image image and range image were removed
v10.0.1.1893
Released 30th November 2023
v10.0.1.1873
Released 14th November 2023
- Implemented Location Clusters functionality for logs, enabling the display of data from both primary and associated locations.
v10.0.1.1837
Released 20th October 2023
- Fixed a bug where previewing a combined log for a location type that had been removed or renamed resulted in the app crashing
v10.0.1.1827
Released 9th October 2023
- Fixed a bug where elevation is incorrect on a quick section if the strip height was modified.
v10.0.1.1821
Released 5th October 2023
- Fixed a bug where text boxes would not persist changes if the user edited and saved log immediately without changing focus to a different merged cell.
v10.0.1.1816
Released 28th September 2023
- Fixed a bug with templates not previewing in some instances where they contain range text library items
v10.0.1.1807
Released 11th September 2023
- Added document xml version to prevent features added to newer versions of studio from being opened with older versions that do not have this feature.
- Added support for new Callouts feature on range items
v10.0.1.1798
Released 6th September 2023
- Bug fix to show a message when a user is trying to open the app on a cloud where the user is not active in.
v10.0.1.1764
Released 8th August 2023
v10.0.1.1737
Released 19th July 2023
- Fixed a bug where an image uploaded directly via template images was not recognized when adding the static image library item.
v10.0.1.1728
Released 13th July 2023
- New library Items added for depth area: "Point Image" and "Range Image"
- These new library items allow the adding of down borehole images at depth on a borehole log
v10.0.1.1724
Released 5th July 2023
- Fixed a bug where Legend Block was available for all templates. Legend Block is now disabled for Header Sheet, Site Plan, Strip, Quick Section and Civils Section.
v10.0.1.1720
Released 30th June 2023
- Fixed a bug where Template Studio would lock up after a longer period of time
v10.0.1.1710
Released 15th June 2023
- Updated the template xml reader compatibility for future template enhancements
v10.0.1.1705
Released 14th June 2023
- Fixed a bug where the preview of a template with Range Text Bar element wouldn't load after saving
v10.0.1.1700
Released 12th June 2023
- Functionality implementation of Customisable Legends used on logs and a new dynamic template called a Project Sheet.
- Please see these articles for more information:
v10.0.1.1652
Released 15th May 2023
- Fixed the clipboard functionality
- Increased default zoom level for strips preview to 150%
v10.0.1.641
Released 14th March 2023
- Support for enabling log generation for Project level Master Template and Strips Sets
v10.0.1.506
- Fixed a bug where log with image grid wouldn't preview on initial load
v10.0.1.489
Released 20th February 2023
- CEFSharp integration for log template previews
- Bug fix for text visibility on Quick log to show continue text on Dynamic Logs where strips hide condition applied
- Bug fix for header sheets preview
- Bug fix where Follow-on Mode prevented previewing if Header and Footer remained the same
v10.0.1.478
Released 19th January 2023
- Fixed a bug with a follow on scale issue
v10.0.1.475
Released 16th January 2023
- Displaying a banner to access US government clouds
- Prompt user re-authentication after period of inactivity
- Fixed a bug where local save overwrites configuration pack template
v10.0.1.456
Released 8th November 2022
- Enable app to connect to commercial and government clouds
- FEDRAMP compliance application shut down logging
v10.0.1.451
Released 26th October 2022
- Fixed a bug with log presentation showing the log squashed in half
v10.0.1.449
Released 12th October 2022
- FIPS compliant app update
v10.0.1.424
Released 19th August 2022
- Added the ability to show the template that is currently open in the top of the window alongside the cloud name.
v10.0.1.421
Released 13th July 2022
- Fixed a bug where office/project logos wouldn't show on site plans
v10.0.1.416
Released 16th June 2022
- App updated after config pack model enhancements
v10.0.1.414
Released 31st May 2022
- Fixed a longstanding issue with problems authenticating due to netwonsoft installation
v10.0.1.408
Released 19th May 2022
- Updated app due to mandatory update required for data collector update 3
v10.0.1.404
Released 13th May 2022
- Fixed a bug where users with project level configurations role couldn't save Ciivls Sections to a Project only Locally
v10.0.1.397
Released 5th May 2022
- Updated app in line with security update to infrastructure
v10.0.1.367
Released 17th February 2022
- updated in line with infrastructure improvements
v10.0.1.361
Released 20th January 2022
- Changed the wording of the strip options dialog to say "hide condition" instead of "visibility condition. This change should make it more obvious what the feature does as it is for hiding strips on logs
v10.0.1.357
Released 12th November 2021
- Added new runtime functions that can pull out the current Template name and Strip Set name. (Information Here)
- Fixed a bug with repeating detailed descriptions which carried over 3 pages.
v10.0.1.354
Released 19th October 2021
- Fixed an issue where strips couldnt be saved because the groups were missing from range text boxes
v10.0.1.352
Released 28th September 2021
- Fixed issue with viewing project/office logo images on Templates
v10.0.1.348
Released 20th August 2020
- Fixed a bug where deleting strip sets from a master template saved under a different name to an existing one would also delete them from the original. Now when you save an existing master template with a new name all strip sets in the new template will have this marker after the name (1). This can be changed at any point.
v10.0.1.346
Released 06th August 2021
- Updated app to support migration to Azure Cloud infrastructure with fixes from previous 336 release which includes a fix for using table names title and not description in group selection.
v10.0.1.336
Released 22nd June
- Fixed a bug which would prevent logs from being previewed in some circumstances as loading the template would remove the group associated with the added library item.
v.10.0.1.291
Released 30th March 2021
- Fixed a bug where the group name would show as the description for the group instead of the title
- Added a new checkbox to Dynamic Logs so it uses the first page header on log transition
v.10.0.1.273
Released 11th January 2021
- Fixed a visual bug with resizing depth columns, when columns were increased and then later decreased it could make the original columns look larger. This didnt affect the actual log preview.
- Fixed a bug where data label headers didnt show when the strip had more than one level in the header on Quick Sections
- Fixed a bug where bar charts border styling options were not being respected.
- Changed the Legend image drop down to now show the picklist groups associated with only the tables linked on the strips when used for Quick Sections.
- Improved the expressions engine allowing the query display of Project Config Packs and Picklist Sets on headers or footers
v.10.0.1.264
Released 04th January 2021
- This update contains the database model updates for AGS 4.0.4 changes. These changes have been communicated in the following communities article:
- Fixed a bug with master fonts. The ribbon font list now uses the same source for fonts but the drop-down will remain blank unless a font is set, unlike before when 'Calibri' would be shown.
v.10.0.1.257
Released 24th November 2020
- Fixed a bug where the correct options were not available for the range text bar library item
- Fixed a bug which would crash Studio if a hbt was loaded which contained templates that didnt exist in that config pack.
v.10.0.1.252
Released 12th November 2020
- Added a fit to width checkbox for strips with graphic items this option now scales by X and tiles by Y resizing the hatch patterns.
- Added a last of index function to the expressions engine
- Example: LocationDetails Phase field = A+B+C. Expression: mid([LocationDetails.Phase], FindLast('+', [LocationDetails.Phase], len([LocationDetails.Phase]) - 1) + 1, len([LocationDetails.Phase])) The result = C
- Fixed a bug which prevented the header or footer area from being increased unless follow on mode was enabled.
v.10.0.1.244
Released 26th October 2020
- Fixed a bug where logs were always being saved to the Project when the Config Pack option was selected.
v.10.0.1.240
Released 22nd October 2020
- Added abliity to set negative increments for barcharts
- Fixed issue where log wouldnt preview when a monitoring pipe library item was added without a instrument type set in Professional
- Fixed an issue where log wouldnt preview if it contained a strip with a rotated text box which also had boundary line set
v.10.0.1.232
Released 14th October 2020
- Added new checkbox option in the strips depth column dialog which can only be be used on civil sections that enables the application of a centre point for the civils header label.
- This change is to solve an issue where if the strip had more than two columns the label would always be shown offset and unable to aligh with the initial columns.
v.10.0.1.229
Released 25th September 2020
- Fixed a bug with follow on headers and footers where the first page header or footer would be the size of the follow on instead.
v.10.0.1.225
Released 12th August 2020
- Added enhancements for Dynamic Logs to show values from strips on first page, last page or first and last.
- Merge option added to Dynamic Log dialog for when data changes based on type.
v.10.0.1.204
Released 02nd July 2020
- Fixed an issue where it wasn't possible to made adjustments to the header and footer area mm sizing of logs/sections
v.10.0.1.196
Released 12th June 2020
- Fixed an issue where the save template button was still active after pressed, this meant users could double press it which would cause Studio to crash and the log corrupted.
v.10.0.1.193
Released 10th June 2020
- Improved error messaging on log preview. If a log fails to preview messaging will be displayed for the following conditions: Missing field validation and Image grid sizing out of bounds
v.10.0.1.187
Released 28th May 2020
- App stability updates
- Restyled the icons when the window is shrunk
Release of OpenGround Cloud
Released 25th April 2020
- Release of OpenGround Cloud and related applications
- Fix for speed issues on Project and Template list loading
All of the notes below are relating to Keynetix.cloud and related products. These are included here for historic purposes.
v10.0.1.153
Released 30th March 2020
- Added validation into the Dynamic Log dialog so that it will prevent preview if incorrect syntax is used in the expression dialog
- Fixed a bug where if you had a blank Template Type in the Dynamic Template dialog it would crash. Now it asks for a valid entry
- Fixed a bug where having small grids for a log follow on would previously show as medium
- Fixed a bug which stopped logs from previewing when a strip hide condition was used.
v10.0.1.140
Released 26th February 2020
- Improved first page/follow on template setup by adding greater precision to units per page.
- field is now decimalised.
- fixed a bug where scale wouldn't show the numbers under certain scale alignment settings
v10.0.1.136
Released 11th February 2020
- Added a new feature for Headers and Footers called, First Page and Follow On.
- The First Page Follow-on functionality allows for a different first page to be used compared to the rest of the log template. For example, this allows for a bigger header and footer area to be used on the first page of the log template, with a smaller area assigned to these on the following pages, allowing for more depth area to be shown.
v10.0.1.124
Released 21st January 2020
- Fixed a bug affecting editing of tables causing the application to terminate.
v10.0.1.110
Released 13th December 2019
- Fixed a bug with previewing site plans.
See user guide for information on how to use the new functionality by clicking here.
v10.0.1.108
Released 11th December 2019
- This release contains addition of new template type called "Dynamic Templates"
v10.0.1.94
Released 29th November 2019
- Updated App for change to API and enhanced Security
v10.0.1.83
Released 11th July 2019
- Fixed display of connector symbols being used for range symbols on logs where previously if the connector carried on to the next page it would not be displayed. (Tile Y Selection only)
- Fixed a bug with displaying the ground scale values correctly if the hole had any inclination values applied.
v10.0.1.81
Released 20th May 2019
- Fixed a bug with quicklogs/log reports displaying. The bug would prevent previewing of the template where there was a vertical scale added which had the flag set for display ground level scale and the locations ground level was greater than 0 but less than 1.
- Fixed a bug with combined logs displaying duplicate data for range text box items where the data is on the transition depth.
v10.0.1.78
Released 16th April 2019
- Fixed a bug with combined logs displaying duplicated and squashed data when a straight line is used as the log transitions to next type.
- Increased app security.
v10.0.1.74
Release 02nd April 2019
Borehole Log 1 saved as a standard Borehole Log Template.
Borehole Log 2 saved as Borehole Log 1 but as a Master Template.
The template will be overwritten but in Enterprise you will see two templates with the same name.
(please note that this change does mean that any template type saved with the same name as a different type of template will overwrite the previous one. For example saving a log as Test Log and a Site Plan as Test Log will mean the original log will be overwritten to become a site plan with the name Test Log.)
v10.0.1.72
v10.0.1.70
v10.0.1.65
v10.0.1.63
Released 28th February 2019
v10.0.1.61
Released 28th January 2019
v10.0.1.59
Release 19th November 2018
v10.0.1.58
Released 1st October 2018
- Added Master Template Support.
- Fixed a bug where the groups selection for creating filter groups wasnt displaying the names instead would be blank.
- Fixed a bug where if you added a office field as a data label text but didnt have an office linked to the project Studio would display a record from the Location Details group.
- The top bar will now show what cloud is currently being used.
