The below information will take you through the updates that are specific to the cloud services. For other information, please consult the respective page.
Released 30th October 2026
- Fixed a bug where it was possible to save a value in a restricted header through the Portal.
Released 27th October 2026
- Fixed a bug where Project Sheets imported with a Test Procedure component were not editable.
Released 22nd October 2026
- Fixed a bug where a report failed to generate if multiple records where selected in a template where a chart with an expression series was used.
Released 29th September 2026
- Fixed a bug with tables were not loading data in templates that reference Summary Groups.
Released 8th September 2026
- Fixed a bug with importing and deleting Summary Groups.
Released 2nd September 2026
- Fixed a bug with well installation graphics not being drawn correctly with well caps.
Released 20th July 2026
- Fixed a bug with cross config-pack querying with custom headers.
Released 15th July 2026
- Fixed a bug with logs not being displayed in situations with installations on logs.
Released 6th July 2026
- Bug fix with import failing if Project had a flag set to null.
Released 29th June 2026
- AGS Export now automatically generates a unique FILE_FSET for records with matching key fields.
Released 25th June 2026
- Import API now correctly uses Project default decimal separator.
- Addition of 2 new system roles in support of ongoing functionality enhancements.
Released 9th June 2026
- Made improvements to the Bulk Replace functionality to support importing picklist headers that are inactive and headers that are restricted.
Released 1st June 2026
- Fixed a bug where extraneuous values are being printed at transition line.
- New API endpoint has been added for map preferences.
Released 28th May 2026
- New API endpoint has been added for grid preferences.
Released 26th May 2026
- New API endpoint has been added for deleting transfer mappings.
Released 25th May 2026
- Fixed a bug with importing AGS documents.
Released 21st May 2026
Released 12th May 2026
Released 30th April 2026
- Fixed a bug with importing pLog documents.
Released 28th April 2026
- Fixed a bug where there was an error when creating a calculated header on a child group that has no key field.
Released 24th April 2026
- Backend updates to future support of AGS 4.2 imports/exports.
- Fixed a bug where exporting data with Testing Schedule did not work.
Released 20th April 2026
- Fixed a bug with incorrectly positioned boundary lines on logs in some situations
Released 16th April 2026
- Fixed a bug with naming convention on new documents uploaded to project or locations when running CSV exports
Released 26th March 2026
- Fixed a bug on AGS exporting with filenames
Released 23rd March 2026
Released 17th March 2026
- Fixed a bug where app would crash if user had "can edit project role" assigned
Released 4th March 2026
- Added dynamic scale for bar chart library items support
Released 2nd March 2026
- Fixed a bug with text being shrunk when used in a table with no fixed row height.
- Fixed a bug where deleting a renamed group would crash Professional.
Released 25th February 2026
- Fixed a bug where publishing laboratory data would show updates to the child records in the summary even though there were no changes published.
Released 17th February 2026
- Update to automated inactivity email sent to create clarity to users regarding the remaining days they can log in for
Released 5th February 2026
- Fixed a bug where /headers endpoint for a group did not return a True value for the IsDepthJoin property.
Released 4th February 2026
- Fix for AGS exports to ensure correct file extensions
- Bug fix for unit conversion on import
- Bug fix for import warnings showing when target fields were included in the mapping file
Released 28th January 2026
- Fixed a bug where it was possible to add a project level header to a system level group.
Released 14th January 2026
- Fixed a bug with unit conversion not correctly converting values on CSV imports
Released 5th January 2026
- Fixed a bug where duplicate picklist grid definition was created when using the API to update a picklist field using the API
Released 9th December 2025
- Fixed a bug with grid counts for soil and rock tables which are filtered based on location id.
Released 2nd December 2025
- Fixed a bug with cross project querying
Released 24th November 2025
- Fixed a bug with importing data
Released 19th November 2025
- Fixed a bug with depth joining properties
- updated Dataforensics plugin
Released 12th November 2025
- Fixed a bug with saved search not showing correct filters applied
Released 22nd October 2025
- Updated Dataforensics Soil Classification Plugin
- Improved stability of Openground
Released 29th September 2025
- Fixed Plog import but where it wasn't caching locations previously selected and reloaded all of them.
- New API endpoints have been added for adding, updating and deleting grid definitions:
Released 22nd September 2025
- Added functionality to omit blank page transition on dynamic logs
Released 11th September 2025
- Backend updated for future development functionality
Released 8th September 2025
- Fixed a bug where hide conditions/expressions were not working correctly on strips used on strip area within quicksections
- Fixed a bug with the data service returning 500 response
Released 4th September 2025
- Added new endpoints to the API that enable the bulk replace functionality:
Released 1st September 2025
- Fixed a bug where certain queries took too long to process which would use up more memory.
Released 28th August 2025
- Fixed a bug where config pack options were lost on export
- Fixed a bug where grid filter groups were being lost on pack export
Released 26th August 2025
- Improved error messages for entering coordinate values that are too large.
- Updates to the data model in support of upcoming capabilities.
Released 22nd August 2025
- Fixed an issue with nested calculations where updating a field that's referenced in a calculation on a child group, blanked out the calculations.
Released 21st August 2025
- Fixed plog file download
- Fixed bug with hbc importing incorrect picklist images
- added restore api snapshot endpoints
- Get Snapshots : {{GatewayUri}}/api/v1.0/data/projects/{{ProjectId}}/snapshots/
- Restore api : {{GatewayUri}}/api/v1.0/data/projects/{{ProjectId}}/snapshot/{snapshotId}/restore
- Check Snapshot Status: {{GatewayUri}}/api/v1.0/data/projects/{{ProjectId}}/snapshot/{taskId}/status
Released 28th July 2025
- Fixed a bug where data on section strips were trimmed off the bottom
Released 23rd July 2025
- Changed some of the errors returned when importing an AGS file to warnings:
- when a field is not recognized as a valid AGS field nor was found in DICT;
- when a picklist doesn't exist in the ABBR table;
- when a unit does not exist in the units table.
- New feature to enable logs to display based on orientation and inclination
- Bug fix for templates failing to generate when legend code was included
- Bug fix for Quick Sections generating from Section Details grid if multiple Section Details with the same name reference different Section Lines
Released 15th July 2025
- Added support for charts components to transfer with config pack export/import
Released 16th June 2025
- Improvements to coordinate systems location projections
Released 9th June 2025
- Improved task service performance
- Fixed a bug where picklist alias isnt respected on import
Released 2nd June 2025
- Fixed a bug where a duplicate key field error was generated when importing an AGS file where the Depth Top on a record in Sample Information group was empty
Released 12th May 2025
- Ability to create snapshots via the API
- Bug fix for rendering issue on Quick Logs
- Bug fix for filter groups group by property where log was not generating if record contained an empty value
Released 29rd April 2025
- Unit support for different units on vertical scale library items
- Fix for aggregate expression on tables
Released 23rd April 2025
- Updated pLOG authentication endpoints
- Row table fix with rounding issue resolved
- fixed bug with viewing correct data series on chart and table
Released 16th April 2025
- The import validation error messages have been updated when:
- the imported value contains more digits than the destination header is configured to store;
- the datetime headers are not formatted correctly;
- the imported number value is not using the correct decimal separator;
- the imported number value contains more decimal places than the destination header is configured to store.
Released 9th April 2025
- Updated the validation error message when a log generation fails due to legacy Rotated Text that doesn't fit to an interval
Released 2nd April 2025
- Updated import validation message format to include group name, title, key headers and value
Released 1st April 2025
- Added option for repeat on new page for range data text items on dynamic logs
- fixed a bug with rotated text where it would always display at the base even if centre aligned.
Released 26th March 2025
- Bug fix for superfluous page with dynamic template page boundary conditions
- Bug fix with legends on log reports
Released 25th March 2025
- Added support for new Section Locations functionality
Released 19th March 2025
- Added support for legacy range data text library items
Released 17th March 2025
- Fixed a bug with initial chainage not being respected via a quick section when chainage is set and saved as a section line.
- Fixed a shrink to fit bug for range data text
Released 12th March 2025
- Fixed a log generation bug where correct strip set name wasnt use when logs transition from one type to another
Released 10th March 2025
- Added support for enhanced range data and point data text support
- added endpoint to get strip sets and strips linked to strip sets
Released 6th March 2025
- Support to allow for additional number formats when exporting CSV
Released 3rd March 2025
Released 28th February 2025
- Fix for detail descriptions on transition line on logs
- Added extra location cluster support
- Added support for Section Details
Released 11th February 2025
- Bug fix for query endpoint when using IN operator with multiple picklist values
Released 27th January 2025
- Fixed a bug with vertical scale adjustments on quick sections
Released 22nd January 2025
- Fixed a bug where table data didn't continue over onto next page.
Released 21st January 2025
- Fixed a bug with row table heights
Released 9th January 2025
- Added enhanced support for vertical scale bar library item metric and imperial.
- Fixed bug with adding/editing data with custom key fields
Released 12th December 2024
- Added enhanced Dynamic Log support
Released 11th December 2024
- Added validation message regarding the maximum number of locations for import. The maximum number of locations is 10000
- Fixed a bug where Symbol Sets were not restarting with the fist symbol if a Chart is paginated
- Updated DF plugin
Released 10th December 2024
- Added support for adding/editing/deleting section lines
- Services updated for new sections workflows
Released 27th November 2024
- Fixed a bug where extra blank pages were generated in templates when using charts in certain circumstances
- Fixed an issue to ensure that the most recent version of an attached document is used during Quick Report and Log Report generation
- Updated the error messaging in Template Studio and Professional when an invalid strip or invalid borehole is being used in a template
Released 25th November 2024
- Endpoint to support API Bulk Updates enabling the retrieval of picklist values and header definitions
Released 20th November 2024
- Horizontal Start, Horizontal End and Pagination Interval has been implemented for sections
Released 19th November 2024
- Bug fix for the query endpoint where duplicate location counts were returned if the cloud had config packs with different schemas and custom headers in the config packs
Released 13th November 2024
- Fixed bug with project setup
Released 7th November 2024
- Added the ability to set row height on tables in templates
Released 6th November 2024
- Added support for Interpolate and InterpolateBFLinear functions
- Fixed a bug where templates without Depth Area stopped producing logs beyond 10 pages
- Fixed a bug where barcharts with the Inverse option ticked were not correctly displayed in the log
- Fixed an issue where the font size of the vertical scale was increased if there was a cover page added to the log
Released 5th November 2024
- Functionality has been added for Template Studio to display symbols from symbol sets in tables for the data shown.
Released 4th November 2024
- Fixed a bug where AGS, CSV or gINT import would fail if there was a field with decimal places set to significant figures or scientific figures
- Security update
- Fixed a bug where importing large amounts of data would not update the calculated fields
- Fixed a bug with table row limits to prevent duplicate charts from appearing across multiple pages
Released 28th October 2024
- Data series Name for charts is no longer automatically added to the Chart Legend in Template Studio
- Fixed a bug where an extra page was being added to a template
- Fixed a bug where a table paginates but the chart doesn't paginate
- Fixed a bug where picklist images were not imported when importing components or creating a new cloud
- Resolved an issue where depth related paging functions did not work for logs with tables
- Enhancement to sections to allow the user to control the Strip Area grid and ticks increments with an expression
- Fixed a bug where the Location Count report showed an incorrect location count in Power Bi because two headers in Location Details with the same name had different data types
Released 22nd October 2024
- Fixed a bug with calculations not updating when ags or csv is imported with sample only
Released 15th October 2024
- Security updates
- Log generation margins were spilling over page
Released 7th October 2024
- Support to allow for additional number formats when importing CSV
- Support to allow for calculations to count the number of non-blank rows and the amount of from a child table
Released 1st October 2024
- Support to allow for evaluation of null equals null values. Enabling user to create calculations to show true or false
Released 30th September 2024
- Support for calculations to allow for retrieval of either the first or last value of a particular field in a group
- Added Average function
Released 25th September 2024
- Bug fix for the query endpoint to support depth linking with custom headers
Released 17th September 2024
- Support for endpoints to retrieve form definitions and reference keys
- Bug fix for data type enums
Released 10th September 2024
- Fixed bug with api crashing pro app when deleting groups
- Added casing depth default values support for data collector
Released 05th September 2024
- Fixed a bug where calculated picklist fields could not be set to null.
- Fixed a bug with inconsistent font sizes for section profiles
- Fixed a bug with hide columns on strip profiles
- Fixed a bug with fixed point not showing on multiple pages on charts
Released 04th September 2024
- Fixed and out of memory exception
- Added enhanced group by behaviour for charts
Released 30th August 2024
- Fixed a bug with location ordering on strip profiles used on sections
Released 29th August 2024
- Fixed an issue where newly imported configuration packs didn't have mapping for location clusters.
Released 23rd August 2024
- Fixed a bug where page borders could not be controlled on sections with strip profiles
- Fixed a bug where pro could crash when adding/removing headers from model manager
Released 8th August 2024
- Fixed a bug with the grid definition query endpoint. now prefiltering is applied to the total count
- Fixed a bug where expressions wouldn't work on project sheets legend blocks
- Non admin users can now have a role assigned for batch import
Released 1st August 2024
- Ability to export and import Strip Profile components
Released 29th July 2024
- Fixed a bug with images on pdf sizes. output size of logs now reduced
- Fixed a bug with calculations of parent fields when only a child table was updated
Released 26th July 2024
- Fixed a bug where if coords entered outside bounds would cause unknown error saving data.
- Fixed a bug with snapshots and custom headers
- Fixed a bug for handling empty expressions on logs
Released 23rd July 2024
- Fix to headers to enable changing from calculated header to non calculated header
Released 16th July 2024
- Fix for where repeated main description on next page was only partially repeated
Released 3rd July 2024
- Couple of fixes for using the data query API endpoint
Released 1st July 2024
- Bug fix for symbol scaling when different page size than the default was selected
Released 27th June 2024
- Bug fix for new cloud creation where it was not possible to generate logs in the default config pack and project.
Released 26th June 2024
- Fixed a bug where stretched symbol scaling made them look thicker
- Fixed a bug where importing data and excluding location details would still import the table which was overwriting
- Fixed a bug where importing a csv file with attached documents the file count in the Data Import dialog was not updated.
Released 18th June 2024
- Fixed a bug with symbol scaling on templates
- Fixed a bug where documents were not correctly uploaded with csv data files
- Added the ability to set centre strip column for Section templates and the ability to hide strip columns for sections only
Released 11th June 2024
- Fixed a bug where having two Legend Blocks with the same Point Symbol as a source in the same template would fail with an error
Released 07th June 2024
- Fixed AGS import error
- Fixed a bug with being able to use the api to page report views
- Fixed a bug with importing picklist values
- Added strip profile functionality
- Fixed a bug with bulk updating inactive to active users would not update their last login date
- Fixed a bug where the charts axis label was not in the correct position scales or axis had a negative direction
- Added validation minimum and maximum values for charts with a logarithmic scale
Released 26th May 2024
- Added EU Localisation number format support for logs
- Fixed a bug where calculated values would dissapear
- Fixed a bug generating pdf file due to storage exception
Released 15th May 2024
- Fixed a bug where deleting custom headers did not delete the headers from the CSV import mapping.
- Updated the error messaging when a template could not be generating because a strip set references a deleted group.
- Fixed a bug where an AGS import would fail with a large import file.
- Bug fix for importing data only into a child group.
Released 8th May 2024
- Fixed a bug where referencing a picklist value in the a calculated field needed to match the case of the picklist.
Released 6th May 2024
- Bug fixed where editing and saving a grid was not possible if that grid included a header with a calculated field that contained an invalid expression with an extra period.
Released 2nd May 2024
- Fixed an issue where Master Templates were not exported via Component Manager.
Released 29th April 2024
- Fix for a bug where importing a single CSV file without its parent group would cause a 'Parent must be set' validation error.
Released 22nd April 2024
- Added support for AGS 4.1.1 Data Format
- Fixed an issue where an error message was shown when changing a QuickList data type to a Long data type for string headers
Released 18th April 2024
- Fixed bugs with AGS export:
- units are exported for fields that use the Evaluate export mapping in AGS 4.0.4, AGS 4.1 and AGS 4.1. AU
- updated the TRAN_AGS to support different 4.1 AU mappings
- Fixed a bug where importing data that matches an existing record with a calculated field that didn't need to be re-calculated was set to null
Released 17th April 2024
- fixed the heading order in the ESCG group in 4.1. AU
- fixed the missing keys in the ELRG export in 4.1
- fixed the heading order for the FILE_FSET heading in different tables for 4.1 and 4.1 AU
- the ISPT_N60 header is no longer added to DICT in 4.1
- the correct data type DT or T is now displayed for specific date time headers in AGS 4.1 and AGS 4.1 AU exports
Released 16th April 2024
- Fixed a bug where some imports were getting stuck at processing calculations
Released 27th March 2024
- Bug fixed for the units per page expressions when there are no records in the project options or report options groups
Released 13th March 2024
- Fix to increase image quality on log production
- Bug fix for pointers pipe work
Cloud Services
Released 5th March 2024
- Added API and Task Service support for Report Options
- Added API and Task Service support for Smart Pointers
- Updated DF Plugins
- Fixed bug with batch gint submission where user was deleted.
- Fixed issue with the map api returning 500's
Released 19th February 2024
- Fixed a bug with using a data query returning location count for deleted locations
- Fixed a bug with importing hbc with custom import mappings
Released 9th February 2024
- Added validation error to prevent plog data with docs from being downloaded if file size exceeds 2GB
- Fixed a bug causing a crash if inactive template used as default for quicklog
- Auto Calculated lat/log easting/northing values in bulk edit api endpoint for the portal
- Fixed a bug with integer data types used in ags import/export
Released 1st February 2024
- Enabled dynamic legend for sections
- Fixed issue with resetting users last login date when user set back to active
- Fixed an API security issue
- Fixed filter group export issue
Released 12th December 2023
- fixed an issue with data entry component export
Released 6th December 2023
- Resolved bugs in Combined Logs where the Split Item placement caused the display of duplicate overlapping data at transition points and where characters where not shown when the detailed description fell just above the page transition
- Fixed a bug where adjusting the Symbol Width property on Legend Blocks impacted the row height
- Plugin updates for Data Forensics Soil Classification
- Updated error messaging for Quick Logs
- Resolved a bug in query pagination, where adding Skip/Take parameters to a query exceeding the query limit would return an exception
Released 4th December 2023
- Improved performance and error logging of data and config pack imports.
Released 30th November 2023
- Updated packages for services
- Improved task service handling of failed tasks. Should now mark them as failed
Released 14th November 2023
- Implemented Location Clusters functionality for logs, enabling the display of data from both primary and associated locations
Released 10th November 2023
- updated the welcome email message
- Improved error messaging on dynamic logs where there isn't the correct template type used
- Fixed bug with log generation which would produce a extra blank page for dynamic logs
- Fixed a bug with config pack import/export that has more than one shift enabled mobile data entry profile
Released 8th November 2023
- Fixed a bug where picklist groups that were not referenced in the model and picklist aliases were not exported
- Bug fix for importing Mobile Data Entry Profiles
Released 7th November 2023
- Plugin updates for Data Forensics Soil Description Builder
Released 2nd November 2023
- Fixed a bug where Power BI cross project querying would fail
Released 1st November 2023
- Added support for location deletion for the OpenGround Portal Technical Preview
Released 23rd October 2023
- Added pagination support to Query endpoint
- Fixed a bug where pipe work on combined logs was not displayed the same way as in standard borehole logs
Released 20th October 2023
- Functionality implementation for Location Clusters - Location Cluster creation, CSV export and CSV import
- Fixed a bug when after importing a new config pack the grid order was incorrect, calculated headers were not marked as active and the data displayed in Field Data Descriptions was displaying data from all active fields
- Fixed a bug where the alignment of rotated text in Quick Logs
Released 13th October 2023
- Added an error message when trying to generate a Quick Log with more than 200 pages.
Released 11th October 2023
- Fixed a bug for exporting a location with attachments that has a null property definition display format.
- Added an error message when trying to enter invalid values for Project Latitude or Longitude.
Released 28th September 2023
- Fixed a bug preventing data saving where location geometry was null
- Fixed a bug with config pack creation where on import calculated fields were deactivated, grid ordering wasn't correct and geology filtered tables showed all fields
- Fixed Task Service for Log Reports with Rotated text items
- Fixed a bug preventing an AGS file Import
Released 21st September 2023
- Fixed a bug for for downloading Data Collector Profiles that have deactivated headers.
Released 20th September 2023
- Increased query limits
- Fixed a bug for Template Studio where rotated text in depth area was not centered.
Released 12th September 2023
- Fixed a bug where a header that was deactivated through Professional was still a part of the step within Data Collector
- Added validation for Shift Start Date field
- Fixed a bug where the Project Sheet could not be generated if the default image was missing
Released 11th September 2023
Released 29th August 2023
- Added action to add step to end shift in Admin Portal
Released 23rd August 2023
- Fixed a bug where the Photographs PickList is deleted from the Document Category group when copying a config pack.
Released 8th August 2023
- Fixed a bug where the user audit log would show an entry every time a user logs in
- Improved hbc import by migrating it to a task instead of an api call.
- Restored an endpoint for generating a Quick Log
Released 1st August 2023
- Enhancements to our API and Task Service logs relating to generating Quick Logs and Log Reports
Released 31st July 2023
- Security updates relating to user deactivation
Released 20th July 2023
- Bug fix for header Unit where it was not possible to change the Unit back to blank if the header had some data saved to it
Released 19th July 2023
- Task Service update to support future functionality enhancements
Released 18th July 2023
- An additional verification for input type of Latitude and Longitude fields added in Task Service for CSV import.
Released 17th July 2023
- Bug fixes for API where querying a child group of Location Details returned a 500 response if one or more projects used a core model configuration pack.
Released 13th July 2023
- API and Task Service support added for log production relating to the new depth related image functionality added to Template Studio
Released 10th July 2023
- Bug fix for the bulk data entry creation/editing API endpoint where an error was returned when editing records in config packs where the schema property was not NULL.
- Fixed a bug where the location count on Admin Portal was not displaying the correct amount.
Released 22nd June 2023
- Bug fixes for Project Sheet component where deleting the component didn't delete the run time logs and the component export didn't create a complete project sheet hbc file.
- Fixed a bug where non-system admin user was unable to create a project
Released 15th June 2023
- Fixed a bug with image grid border control being incorrect and borders around images not being displayed correctly
- Update to plugin for soil classification
Released 14th June 2023
- Fixed a bug with changing the data type of a custom groups header for new schema config packs.
Released 12th June 2023
- Functionality implementation of Customisable Legends used on logs and a new dynamic template called a Project Sheet.
Cloud Services
Released 9th June 2023
- Updated to ensure running multiple tasks simultaneously doesn't crash Enterprise
Cloud Services
Released 7th June 2023
- Updated to remove Last Login Date from User Details form
Cloud Services
Released 1st June 2023
- Updated to add additional banner text
Cloud Services
Released 26th May 2023
- Bug fix for log generation where units per page on running initial quicklog did not match settings in Studio.
- Work around at the time was to change the units per page and then set them back to desired number.
- Added operation risk fixes for log report generation to fix memory leak issues
- Increased picklist join limit which was affecting some excel reports with many picklists
- Fix to storage service preventing document downloads saved with non ASCII characters
Released 17th May 2023
- Moved Calculated Field updates to run via a task which is processed in the background
- Option added to check status of task processing
- Adding new or editing a calculated field will recalculate for all projects using that Config Pack
- API endpoints added for enabling of multiple creation/editing actions at once for data entry
Released 28th April 2023
- Bug fix for Replicate Locations where replicating boreholes would replicate children across multiple projects
Released 26th April 2023
- Attaching log on syncing to cloud from Data Collector
- Endpoints added to enable Replicate Locations functionality
- Task type implemented to enable replicate location functionality
- Support for enabling log generation for Project level Master Template and Strips Sets
Released 14th March 2023
- Bug fix for log templates. Vector tiled symbols which start exactly at page transition are ignored
- Bug fix for dynamic logs should always plot the straight line library item on log transition sections
- Bug fix for log report generation via the API
Released 20th February 2023
- Bug fix for log template preview
- Bug fix for text visibility on Quick log to show continue text on Dynamic Logs where strips hide condition applied
- Bug fix where updating Active flag on header didn't make it inactive
- Update to logs to capture missing roles for user
Cloud Services
Released 9th February 2023
- Bug fix for Adding custom headers where in certain situations it wouldn't save the header correctly. Header would show in manage model but not in the grid.
- Improved component transfer to allow Master Templates with Strip Set components to transfer between different config pack schemas
- Fixed site plan viewing which was affected by a recent Microsoft Windows update
- Fixed our API logs to show Correlation ID, URL or Instance ID
- Fixed a bug with the API where you would get wrong 400 error message response querying a Project that doesn't exist
- Added a new link to the welcome emails for "getting ready for OpenGround
- Fixed a bug where ncalc issues are throwing errors instead of warnings for internal logging
Cloud Services
Released 31st January 2023
- Bug fix for display format of decimals in grids. When making edits to those fields in Model Manager, decimals were lost
- Bug fix for Dynamic logs where the scale was inaccurate for units per page when set
- Bug fix for handling custom properties specified at project level to prevent application crashing
- Bug fix for allowing a different user to import data that was uploaded via portal using a different user
- Bug fix to include the export LBST_TO field mapping. This wasn't being exported previously
- Bug fix for Saved Searches not loading
- Enhancement on recording information on service logs
- Bug fix for gINT data import
Cloud Services
Released 9th January 2023
- Limit the number of concurrent sessions
- Limit character sets to Unicode
- Improved security logging
- Feature tracking
- Additional endpoint for Model Management
- Support for Civil 3D 2023
Web API Build 1759465
Released 8th November 2022
- Core model enhancements to allow non-model and non-picklist components to be transferred between schemas
- Fixed a bug with querying on multiple filters
- Fixed a bug to enhance cross project queries using different schemas
- FEDRAMP compliance for FIPS
- FEDRAMP compliance fix for task status
- FEDRAMP compliance for access control
- FEDRAMP compliance for process name in logs
- Fixed a bug with calculated fields throwing unhandled exception
Task Service Build 1761897
- FEDRAMP compliance application shut down logging
- Fixed a bug with import mapping errors
Web API Build 1742639
Released 26th October 2022
- Improved functionality for exporting/importing mobile data entry profiles
- Fixed a bug where it was possible to create a project with an invalid config pack id and edit one too
Task Service Build 1742595
- Fixed a bug with exporting csv data with documents where only some locations were selected
- Fixed a bug with AGS 4.1 exporting data as SF would actually export as U
- Fixed a bug with 4.0.4 export for PMTL group
- Fixed a bug where WGPG headers were missing from 4.1UK Schema
- Fixed a bug where the default export mapping wasnt being returned as the first selection in the list
Web API Build 1712860
Released 11th October 2022
- FedRAMP compliance for removal of MD5 Checksum on document transfer
FedRAMP compliance Web API returns HTML instead of JSON
- Fixed bug with extension tables
Task Service Build 1709545
Web API Build 1646459
Released 1st September 2022
- FedRAMP compliance for hardened containers
- Added validation for when custom headers are deleted from professional but referenced in a mobile data entry profile
- Fixed a bug where if photos are uploaded from Data Collector app and the config pack doesnt contain the document category "Photographs" the api will create this category so there are no errors uploading the photos
- Added validation to inform users that quick section cannot be run as locations fall outside the project coordinates bounds
Task Service Build 1646476
- Fixed a bug with AGS Export mappings not showing correct version in the TRAN Table
- Fixed a bug with gINT data lookup for updating data
- Fixed a bug where log template applied to mobile data entry profile wasn't transferred on export
- Fixed a bug for imports with duplicate samples in test schedule not displaying errors correctly
Web API Build 1618789
Released 19th August 2022
- Added validation to components import to prevent transfer between different schemas
Task Service Build 1618796
- Fixed a bug with bulk update
- Fixed a bug with ags importing documents
Web API Build 1605274
Released 5th August 2022
- Added limit to amount of data that can be queried against all project. limit is 250,000 records.
Task Service Build 1599686
- Fixed a bug with config pack importing losing strip set links which would need to be reapplied again in Template Studio
Web API Build 1583039
Released 28th July 2022
- Fixed a bug where long index names were invalid
- Fixed a bug with AGS 3.1 import validation issues
Task Service Build 1584572
Web API Build 1552221
Released 13th July 2022
- Fixed a bug with data querying auth user info. The bug caused the query to hang indefinitely
- Fixed a bug with quick sections not working in certain circumstances
Task Service Build 1552226
- Fixed a bug with IPID/IFID data not exporting correctly
- Fixed a bug with exported config packs would lose their strip set links for report profiles and quick logs under manage templates
Web API Build 1538709
Released 4th July 2022
- Removed the ability to query legacy passwords from the auth user table in the cloud db.
- Fixed issues with project data querying
- Fixed bugs related to the changes for the new config pack model updates
Task Service Build 1511430
- Updated inline with config pack model updates
- Added missing import mapping function
MAP API Build 1503208
Released 16th June 2022
- Fixed a bug with 500 errors for map tiles not loading
Web API Build 1508551
- Added a deletion endpoint for removing Project Coordinates
- Fixed some 500 errors on cross project querying
- Config pack model enhancements
- Fixed issues with creating snapshots in certain circumstances
- Enhancements to config pack model
Web API Build 1472698
Released 31st May 2022
- Fixed a bug with think geo relating to incorrect coordinate system reprojections.
Task Service Build 1472743
Web API Build 1450786
Released 19th May 2022
- Support for Shift Enabled Mobile Data Entry Profiles
- Improvements to component importing for Units and Unit Groups
- Fixed API cross site scripting weakness for Portals
Task Service Build 1463212
- Fixed a bug with exporting AGS 4 data for date time fields. Previously would always export miliseconds.
- Fixed importer for a bug where newly mapped fields were not recognised in the mapping
Web API Build 1450087
Released 13th May 2022
- Added timeout to Query enpoint to prevent large queries afecting cloud performance
Task Service Build 1451199
- Improved speed of very large data imports
- Fix issue which will resolve startup time of Jumbo tasks
Web API Build 1341569
Released 14th March 2022
- Fixed a bug with cross project querying which would result in a 500 error message
Web API Build 1212531
Released 17th December 2021
- New Excel Report endpoints added
GET {{WebAPIRegion}}/api/v1.0/configuration/packs/{configPackId}/excelreports
GET {{WebAPIRegion}}/api/v1.0/configuration/projects/{ProjectId}/excelreports
- Fixed Swagger on Sandbox
- Added functionality to restrict project access for new users if project restrict flag is set and new projects when setting the flag on create
Web API Build 1159509
POST {{WebAPIRegion}}/api/v1.0/configuration/packs/{configPackId}/model/groups
POST {{WEBAPIRegion}}/api/v1.0/configuration/packs/{configPackId}/model/groups/{groupId}/headers
POST {{WEBAPIRegion}}/api/v1.0/configuration/packs/{configPackId}/picklistgroups
POST {{WEBAPIRegion}}/api/v1.0/configuration/packs/{configPackId}/picklistgroups/{picklistGroupId}/picklists
Web API Build 1111551
Released 18th October 2021
- Fixed a bug where the validation endpoint would throw a 500 response for a user who had the create project role only at system level.
Web API Build 1085489
Released 28th September 2021
- Fixed a bug which affects the Admin Portal. Bug was the API wouldnt allow the addition of a field which has the same name as its parent group.
Task Service Build 1150226
Released 12th September 2021
- Fixed the way the task service handles importing files that have different decimal precision.
- Fixed a bug which prevented the task service from logging exceptions for reporting errors to debug
- .Fixed task service so it self terminates when its has a fault.
Web API Build 1061598
Released 10th September 2021
- API updated to improve logging within the Azure Infrastructure
Task Service Build 1064779
- Fixed a bug with gINT imports where the "import project data" option was selected.
- Fixed a memory leak with the task service
- Improved the import process to prevent tasks from failing and still showing as running in the back end.
- Improved task service logging so certain errors ar now shown as warnings
Web API Build 1021844
Released 13th August 2021
- Updated the following grid definition API endpoints. The update was to facilitate report views use in the Power BI Connector
{{WebAPIRegion}}/api/v1.0/configuration/system/griddefinitions
{WebAPIRegion}}/api/v1.0/configuration/system/griddefinitions/{GridId}
WebAPIRegion}}/api/v1.0/configuration/projects/{ProjectId}/griddefinitions
WebAPIRegion}}/api/v1.0/configuration/projects/{ProjectId}/griddefinitions/all
WebAPIRegion}}/api/v1.0/configuration/projects/{ProjectId}/griddefinitions/{GridId}
