The below information will take you through the updates that are specific to this application. For more general information and product update videos, please see the general New Release page.
v10.0.1.3551
Released 16th September 2026
- Bug fix for System Admin Audit log
v10.0.1.3540
Released 11th September 2026
v10.0.1.3536
Released 8th September 2026
- Fixed a bug where Test Procedure modal did not show all of the groups in the Groups table.
v10.0.1.3527
Released 26th July 2026
v10.0.1.3510
Released 21st July 2026
- Added support for portrait orientation on section logs.
v10.0.1.3507
Released 15th July 2026
- Support for Test Procedures in lab configuration packs to allow for standardized testing lab data entry and reporting.
- Added the ability to create and configure Summary Groups to support reporting.
- Fixed a bug where it was possible to enable/disable plugins from the project level.
v10.0.1.3490
Released 29th June 2026
- Updated app with foundation for upcoming functionality (no new features).
v10.0.1.3480
Released 19th June 2026
- Fixed a bug where the project user access grid was missing the Office column.
v10.0.1.3478
- Fixed a bug when saving data from the grid.
v10.0.1.3472
Released 17th June 2026
v10.0.1.3458
Released 15th June 2026
- Fix to Submissions grid to disable Download Mapping File button if linked Import Mapping missing, preventing crashing.
v10.0.1.3451
Released 9th June 2026
- Bug fix for error messages on import.
v10.0.1.3448
Released 4th June 2026
v10.0.1.3444
Released 3rd June 2026
v10.0.1.3433
Released 1st June 2026
- Bug fix where Requested By column was empty in the Laboratory projects connections window.
v10.0.1.3428
Released 27th May 2026
v10.0.1.3409
Released 19th May 2026
- Updated browser control for the pdf viewer with the app.
v10.0.1.3402
Released 12th May 2026
- Bug fix with Snapshots allowing user to click No on Restore Snapshot confirmation dialog.
v10.0.1.3393
Released 5th May 2026
v10.0.1.3384
Released 27th April 2026
- Fixed a bug where Schedule Reference was not highlighted as a key field in the Test Schedule modal.
v10.0.1.3357
Released 13th April 2026
v10.0.1.3350
Released 7th April 2026
- Updated the Testing Schedule grid to be read-only.
v10.0.1.3350
Released 23rd March 2026
- Fixed a bug where if the user that created a Connection request was deleted, opening the Laboratory Projects would cause the app to crash.
- Fixed configuration pack right-click options for managing Data Entry Profiles.
v10.0.1.3340
Released 17th March 2026
- Fixed a bug where if the user has "can edit project' role app would crash when changing the coordinate system.
v10.0.1.3323
Released 2nd March 2026
v10.0.1.3321
Released 25th February 2026
- Fixed a bug where Unit Group conversion factor was allowing invalid figures.
v10.0.1.3314
Released 23rd February 2026
- Fixed a bug where creating a custom project level group would lead to Professional crashing.
- Source picklist header publishing mapping in engineering config packs do not need to include the uui_ prefix anymore.
v10.0.1.3309
Released 16th February 2026
v10.0.1.3305
Released 12th February 2026
v10.0.1.3300
Released 9th February 2026
v10.0.1.3293
Released 4th February 2026
- Geotechnical laboratory testing and reporting is now supported in OpenGround. For more details see the announcement.
v10.0.1.3293
Released 3rd February 2026
- Our charting engine can now natively support circular data series, allowing for example for Mohr's circles to be generated and visualized.
v10.0.1.3274
Released 2nd February 2026
- Updated Unit Groups functionality to allow users to Manage Unit Groups
- Create, update & delete Unit Group
- Create new Units along with conversion and offset factors
v10.0.1.3259
Released 27th January 2026
v10.0.1.3257
Released 15th January 2026
- Fixed a bug where the value of an uncommitted grid cell was not saved when exiting the edit view.
v10.0.1.3249
Released 14th January 2026
- Functionality to manage unit groups
v10.0.1.3233
Released 12th January 2026
v10.0.1.3228
Released 11th December 2025
v10.0.1.3218
Released 9th December 2025
- Fixed a bug where deleting a config pack would lead to Professional crashing.
v10.0.1.3208
Released 4th December 2025
v10.0.1.3206
Released 2nd December 2025
v10.0.1.3197
Released 24th November 2025
- Fixed a bug where opening the modal for Manage Picklist Sets would lead to Professional crashing.
v10.0.1.3197
v10.0.1.3172
Released 17th November 2025
- Fixed an issue where creating a custom group inside a project would lead to Professional crashing.
- Updated the name of the Create Project access role to Create Engineering Project.
v10.0.1.3146
Released 10th November 2025
v10.0.1.3107
Released 13th October 2025
- Added the option to filter the Chain of custody samples.
v10.0.1.3097
Released 7th October 2025
- Enhancement to snapshot functionality and an update to fix a bug with project refresh
v10.0.1.3075
Released 22nd September 2025
- Bug fix for Data Entry where duplicate grids on separate config packs would throw a validation error
v10.0.1.3066
Released 17th September 2025
v10.0.1.3053
Released 11th September 2025
v10.0.1.3050
Released 9th September 2025
- Fixed a bug where it was not possible to export Project Sheets with the Page By option set
- Bug fix where QuickLog button was not visible upon opening a project
v10.0.1.3040
Released 8th September 2025
v10.0.1.3038
Released 4th September 2025
- Fixed a bug where adding a Section Line marked the cloud to be recalculated.
- It will not be possible to save Section Lines with any older version of Professional. Version 10.0.1.3038 is required for Section Lines to work.
v10.0.1.3034
Released 2nd September 2025
v10.0.1.2016
Released 29th August 2025
- Fixed a bug where quick section from section details would incorrectly show excluded locations that were excluded from a differently saved section details that share the same section line
v10.0.1.3016
Released 20th August 2025
- Fixed a bug with user authentication preventing plog files from downloading
- Fixed a bug with filter values not being saved when editing filterable grids via manage model/manage grids
- Improved logging for issues with duplicate headers
- fixed a bug with incorrect picklist images being imported with components.
v10.0.1.3005
Released 12th August 2025
- Bug fixed where bulk editing of a grid would not display the filtered count of rows that are being updated
- Fixed a bug where the filtered row count of a grid would not be correct
- Fixed an issue where grouping of picklist headers would only return an empty result
v10.0.1.2976
Released 4th August 2025
- Fixed a bug which crashed the mapping functionality
v10.0.1.2976
Released 23rd July 2025
- Bug fix for Quick Sections generation from Section Details grid if multiple Section Details with the same name reference different Section Lines
v10.0.1.2971
Released 18th July 2025
- Fixed bugs with columns shifting out of order on report views
v10.0.1.2965
Released 15th July 2025
- Mandatory security update
v10.0.1.2948
Released 8th July 2025
- Fixed bug with bing mapping
v10.0.1.2908
26th June 2025
- Updated app with mandatory security updates
v10.0.1.2898
Released 16th June 2025
v10.0.1.2886
Released 02nd June 2025
- Fixed a bug with ags import with no depth top
- Fixed a bug with projec access not working inside a project
- Fixed a bug where pro would crash doing a quick log in certain circumstances
v10.0.1.2845
Released 29th April 2025
- Updated user roles to enable Project managers the ability to manage user access to projects they have access to
v10.0.1.2842
Released 23rd April 2025
- Updated pLOG authentication endpoints
v10.0.1.2830
Released 2nd April 2025
- Bug fixes for Section Location tooltips and save button
- Updated import validation message format to include group name, title, key headers and value
v10.0.1.2817
Released 25th March 2025
- Added Section Locations functionality. New dialog for saving locations used in sections
- new table for saving excluded locations from sections and section offset
v10.0.1.2812
Released 20th March 2025
- Fixed a bug where saving section details would crash if locations were selected via selection tool and no alignment line drawn
v10.0.1.2798
Released 11th March 2025
- Bug fixed for token refresh where it signed user out and crashed when attempted to sign back in
v10.0.1.2773
Released 6th March 2025
- Support to allow for additional number formats when exporting CSV
- Update to import wizard to include group name and title
v10.0.1.2760
Released 27th February 2025
- Added new section details table to the sections sub folder within the project explorer
- Section parameters are saved within this table and quick section can be run with saved parameters directly from this grid.
- Custom fields can be added and referenced via expressions in Studio
v10.0.1.2753
Released 20th February 2025
- Updated security of document upload/downloads.
v10.0.1.2746
Released 17th February 2025
- Fixed a bug where user was unable to create data entry profile with the same name on configuration pack that was created from a copy
v10.0.1.2718
Released 11th February 2025
- Fixed a bug adding steps to data entry profile
- Added new functionality to delete config packs that are not linked to any projects. Once deleted, they cannot be retrieved.
v10.0.1.2711
Released 6th February 2025
- Fixed a bug validation error message was incorrect when uploading a document to a project failed
v10.0.1.2703
Released 3rd February 2025
- Fixed a bug where duplicate custom tables could be created if the title of the custom table was changed
v10.0.1.2690
- Fixed a bug where map dataset couldnt be disabled
- Fixed a bug where manage grids button wasnt disabled for Project Options Groups
v10.0.1.2681
Released 21st January 2025
- Fixed a bug where stripset dialog would crash the app
- Added vertical scale options to quick sections
v10.0.1.2649
Released 10th December 2024
- Fixed a bug where some projects took a long time to open or couldn't be opened
v10.0.1.2640
- Added functionality for section alignments.
- New table in project explorer. can create via the grid
- Can create alignment via entering coordinates in well known text format
- can do quick section via the new ribbon
- all existing alignments moved to new grid
v10.0.1.2620
Released 20th November 2024
- Horizontal Start, Horizontal End and Pagination Interval has been implemented for sections.
v10.0.1.2612
Released 18th November 2024
- Fixed an issue with updating picklist items so the updates to values propagate through all the projects
v10.0.1.2604
Released 5th November 2024
- Fixed an issue where the Manage Components dialog crashes if charts are present
v10.0.1.2592
Released 4th November 2024
- Fixed an issue where adding a custom field to the system level group Test Type would lead to a crash when opening the Manage Test Schedule dialog
- Fixed a bug where clicking Setup Project would crash the app under specific circumstances
v10.0.1.2563
Released 15th October 2024
- Security update patch
- Fixed a bug where inactive components were still showing
v10.0.1.2552
Released 7th October 2024
- Support to allow for additional number formats when importing CSV
v10.0.1.2536
Released 25th September 2024
- Fixed a bug where depth linking with custom fields would cause duplicate records to be displayed in the grid.
v10.0.1.2525
Released 17th September 2024
- Security fix for PDF Viewer
- Support for endpoints to retrieve form definitions and reference keys
- Bug fix for data type enums
v10.0.1.2502
Released 29th August 2024
v10.0.1.2484
Released 8th August 2024
- Added ability for non admins to use batch import if correct security role is applied
- Fixed a bug with importing data with batch documents
v10.0.1.2473
Released 1st August 2024
- Ability to export and import Strip Profile components
v10.0.1.2462
Released 31st July 2024
- Fixed a bug where trigger sets were not working as intended
v10.0.1.2425
Released 2nd July 2024
- Addition of 2 new system roles to enable request history retrieval
v10.0.1.2420
Released 20th June 2024
- Updates to caching of the background mapping
v10.0.1.2414
- Fixed a bug where the background mapping wasn't showing
v10.0.1.2408
Released 19th June 2024
- Fixed a bug that allowed the deletion of a picklist used in data grids within a project
v10.0.1.2405
Released 12th June 2024
- Fixed a bug where values for all mappings were displayed when opening mapping for a specific field in the group Liquid Limit and Plastic Limit
- Updated app error logging
v10.0.1.2390
Released 6th June 2024
- Added new Strip Profile Functionality to Professional
v10.0.1.2376
Released 23rd May 2024
- Fixed a bug affecting decimals displayed using expressions on log production.
- Fixed a bug where Professional crashes if a table that is Project or Report Option flagged has its name changed
- Fixed a bug where the UI prevented changing tables in the models position in the project explorer.
- Added config pack settings for changing number formats (EU Localisation Support)
v10.0.1.2328
Released 1st May 2024
v10.0.1.2308
Released 18th April 2024
- Fixed an issue where GPU Cache and DawnCache folders were created on Desktop instead of the appropriate Local App Data folder
- Bug fix for Professional crashing when selecting Manage Grids on Location Clusters group in Model Manager
- Enabled AGS 3.1 mappings that are not the default ones from being removed
v10.0.1.2298
Released 16th April 2024
- Fixed a bug where an error message was shown when a header was added to a System Model group
- Bug fix for switching display types of existing headers
- Disabled the Toggle Active button for Picklist Sets
- Bug fix for changing a field from String to QuickList
v10.0.1.2264
Released 27th March 2024
- Added missing validation to when importing data with missing parent location IDs
v10.0.1.2235
Released 5th March 2024
- New Feature added for Project and Report Options
- Bug fix: Deleting users will delete the batch import submission
v10.0.1.2217
Released 26th February 2024
- App updated to support future OpenGround release of Report Options.
v10.0.1.2200
Released 9th February 2024
- Fixed a bug creating new trigger sets.
- Bug fixes with Associated Locations causing crashes, spelling mistake fix and import data issue.
- gINT bulk import feature now available.
v10.0.1.2188
Released 1st February 2024
v10.0.1.2174
Released 22nd January 2024
- Fixed a bug where export model hbc would export all the packs filter groups instead of the actual model items. If no filter groups for that model item it would show all as well.
- Updated app security
- Fixed an issue with adding wms mapping layers
v10.0.1.2152
Released 12th January 2024
- Added new Bulk Update Coordinate Systems button. This button adds the functionality to select multiple projects and update the project coordinates to a different system
- This will also move the locations and update project bounds
- Enabled importing CSV with other delimiter and quote character options
- Security fixes.
v10.0.1.2099
Released 7th December 2023
- Fixed a bug where a grid wouldn't load if the a custom field is selected as a depth header
v10.0.1.2094
Released 6th December 2023
- Updated the User Guide link
v10.0.1.2092
Released 5th December 2023
- Fixed a bug with data filtering and bulk update failures
v10.0.1.2086
Released 4th December 2023
- Resolved an issue preventing the preview or download of uploaded documents when the file size did not match the actual file size.
v10.0.1.2057
Released 14th November 2023
- Resolved a bug in the location cluster dialog that briefly caused all locations to be displayed as associated locations upon initial load.
v10.0.1.2049
Released 13th November 2023
- Improved component import for mobile data entry profiles
- Improved the functionality to ensure that selecting the option to overwrite empty values when importing a CSV file now effectively replaces the existing values as intended
v10.0.1.2038
Released 8th November 2023
- Fixed a bug where picklist groups that were not referenced in the model and picklist aliases were not exported
v10.0.1.2021
Released 23rd October 2023
- Bug fix for Project Sheets where legend data would be shown for all locations instead of the selected or filtered one
- Fixed a bug where editing a logo created a new logo
v10.0.1.2007
Released 20th October 2023
- Functionality implementation for Location Clusters - Location Cluster creation, CSV export and CSV import
- Added an error message when trying to generate a Quick Log with more than 200 pages
v10.0.1.1985
Released 10th October 2023
- Bug fix for system fields present in manage grids
v10.0.1.1983
Released 5th October 2023
- Fixed a bug where importing a picklist csv with a defined display order would set every picklists display order to 0.
v10.0.1.1972
Released 4th October 2023
- Fixed a bug with grid filtering on some picklist fields
v10.0.1.1962
Released 21st September 2023
- Fixed a bug where it was not possible to import third party components into configuration pack.
v10.0.1.1940
Released 11th September 2023
- Fixed issue downloading plog data with documents that are over 800mb in total download size
- fixed a bug with manage grids in model manager where hasdata field could be removed and not returned
v10.0.1.1931
Released 5th September 2023
- Bug fix to show a message when a user is trying to open the app on a cloud where the user is not active in.
v10.0.1.1930
Released 31st August 2023
- Updated Professional compatibility with future functionality enhancements
v10.0.1.1869
Released 08th August 2023
- Fixed a bug where the user audit table would be updated with an entry every time a user logged in
- Fixed a UI bug where the picklist sets button was enabled in the picklist manager even if there are no picklist sets created
- Improved hbc importing
v10.0.1.1835
Released 24th July 2023
- Updated the dataset import message to inform users that the dataset coordinate system must match the coordinate system defined for the Project.
- Bug fix allowing the system level grids to be refreshed automatically after adding a custom field.
v10.0.1.1819
Released 20th July 2023
- Adjusted the UI for Pick List Manager and Edit Picklist Group dialog to display the Delete button as the last button in the row on the left side to keep in line with other dialogs throughout Professional
- Bug fix for header Unit where it was not possible to change the Unit back to blank if the header had some data saved to it
v10.0.1.1813
Released 17th July 2023
- Fixed a bug where the app would crash after attempting to change the Test Type Category of Scheduled Tests.
v10.0.1.1794
Released 12th July 2023
- Fixed a bug where it was possible to remove a key field from the Project grid.
v10.0.1.1781
Released 5th July 2023
- Fixed a bug where it was possible to delete rows in the Replicate Location grid
- Fixed a bug where it was possible to crash the app and create duplicate custom headers if the save button was pressed in quick succession
v10.0.1.1770
Released 30th June 2023
- Fixed a bug where it was possible to crash the app and create duplicate custom groups if the save button was pressed in quick succession
v10.0.1.1756
Released 22nd June 2023
- Bug fixes for Project Sheet component where deleting the component didn't delete the run time logs and the component export didn't create a complete project sheet hbc file.
v10.0.1.1742
Released 21st June 2023
- Improved how the app responds to internet dropping connection
v10.0.1.1732
Released 12th June 2023
- Functionality implementation of Customisable Legends used on logs and a new dynamic template called a Project Sheet.
v10.0.1.1715
Released 7th June 2023
- Bug fix for replicate locations where user could edit the group name in the grid
v10.0.1.1702
Released 26th May 2023
- Fixed a bug with test scheduling where tests would be removed from the schedule on re-edit.
v10.0.1.1680
Released 17th May 2023
- Improved config pack and project calculated fields processing.
- Recalculated fields run as a task in the background
- New check calculations button was added to the system ribbon for checking the status of calculations
- Please see this article for more information
- Bug fix to the system model manager for the project. In Manage Grids Coordinate System and Config Pack were originally labelled as just Name now it says what the fields are.
v10.0.1.1661
Released 3rd May 2023
- Bug fix for trigger sets where validation fails prevented importing triggers,
- Bug fix for excluding Ground Model group when exporting as CSV,
- Enabling window resizing for laboratory schedules test details dialog,
- Bug fix for pLog imports where fields were not refreshing when importing data,
v10.0.1.1643
Released 26th April 2023
- Functionality implementation of Replicate Locations
- Support for enabling log generation for Project level Master Template and Strips Sets
- Bug fix for enabling users who have role "Link Users" to be able to view assigned Project Access dialogs, Add/Remove assigned users to Projects they have access to
v10.0.1.1572
Released 14th March 2023
- Fixed a bug where the checkbox for setting a group to be active/inactive didn't work
- Fixed a bug where the log report option was missing from the reporting dialog when selecting locations from the map.
- Fixed a bug where an error would occur creating a header in the geology table if the config pack contains grid splitting in the geology table.
v10.0.1.1548
Released 20th February 2022
- Bug fix allowing for system level picklist header creation
- Bug fix where error in grid prevented uploading and viewing of documents
- Bug fix where updating Active flag on header didn't make it inactive
v10.0.1.1500
Released 9th February 2022
- Fixed an issue with site plan viewing due to a Microsoft Windows Update
v10.0.1.1470
Released 31st January 2023
- Bug fix for loading project forms to prevent crashing
v10.0.1.1450
Released 9th January 2023
- Displaying a banner to access US government clouds
- Prompt user re-authentication after period of inactivity
- Expire inactive accounts
- Revised mapping issue to enable excluded fields to be imported
- Fixed a bug to stop crashing when updating header name
- Fixed a bug with Document Conflicts with New Config Packs
v10.0.1.1356
Released 8th November 2022
- Enable app to connect to commercial and government clouds
- FEDRAMP storage access logging
- FEDRAMP compliance application shut down logging
v10.0.1.1321
Released 26th October 2022
- Improved mobile data entry component transfer so it does not take all the model changes with it which would overwrite the model in the destination config pack.
- Only the profiles are transferred now
- Added a button to copy the list of any errors returned after import to clipboard
- Fixed a bug with exporting csv data with documents where only some locations were selected
- Fixed a bug with AGS 4.1 exporting data as SF would actually export as U
- Fixed a bug with 4.0.4 export for PMTL group
- Fixed a bug where WGPG headers were missing from 4.1UK Schema
- Fixed a bug where the default export mapping wasnt being returned as the first selection in the list
v10.0.1.1307
Released 13th October 2022
- Fixed a bug which would cause grids to take minutres to open
v10.0.1.1288
Released 11th October 2022
- Fixed a bug where app would crash when pressing the options dialog in the users ribbon
- Fixed a bug where app would crash when downloading/viewing file with invalid file name
- Added FedRAMP requirement to remove MD5 checksum on document transfer
v10.0.1.12117
Released 2nd September 2022
- Fixed a bug with app crashing when right clicking to add/edit data to a grid then clicking on the add bar would crash app when description field uses a quicklist
- Added validation check for deleting picklist set that is linked to a mobile data entry profile
- Fixed bug with crashing app when trying to save a picklist that has text in the order field
- Added users date time for their region to the audit log
- Fixed a bug with ags export not showing correct version in the TRAN table
v10.0.1.1195
Released 19th August 2022
- Removed unused windows authentication field from user management
- Added validation to components importer to prevent transfer of components from config packs with different schemas
- Fixed an issue with bulk updating custom fields
- Fixed an issue with activating new coordinates systems where the dialog wouldnt refresh
- Shift table fields can now be added to children of samples
- Fixed a bug with column reordering
- Fixed a bug with importing ags files with documents
v10.0.1.1160
Released 05th August 2022
- Fixed a bug where ags export would fail in certain circumstances using the ags 4.0.3 upgraded mapping
- Fixed a bug with Config Pack export where on import of the pack it would lose the strip set references so they would have to be reapplied again in Template Studio
v10.0.1.1153
Released 28th July 2022
- Fixed a bug with creating schedule with no Laboratory or Reference
- Fixed a bug with deactivating calculated headers
- Fixed a bug with group name character limit
- Fixed a bug with error message on duplicate picklist/quick list definition
- Fixed a bug with config pack validation rules
v10.0.1.1116
Released 13th July 2022
- Fixed a bug where project/office logos won't display on site plans
- Fixed a bug with quick sections which use the new config pack updates
- fixed a bug where the validation rules for overlapping geology and the base depth being lower than top depth wouldn't work in certain conditions
- Fixed a bug with reprocessing calculations which would generate incorrect error messages
- Fixed a bug so that the AGS mapping drop down always shows default as the first choice and not a custom mapping which in alphabetically first
- Fixed a bug which would cause strip sets on master templates to lose their links on export so on import the report profiles and quick logs wouldnt show the correct strip sets
- Fixed a bug with the quicklist manager where if you changed the name of a picklist group it wouldn't update the quicklist manager.
v10.0.1.1089
Released 4th July 2022
- App updated after model config pack enhancements
- Minor bug fixes
- Fixed a bug with mapping which would crash the app
v10.0.1.1050
Released 16th June 2022
- App updated after config pack model enhancements
- Fixed a bug where the add/edit button for Offices would crash the app if it was pressed
v10.0.1.1016
Released 31st May 2022
- Fixed a bug with think geo relating to incorrect coordinate system reprojections.
v10.0.1.1005
Released 19th May 2022
- App update for Data Collector Update 3 Shift Support
- New shift selection box added to the quicklog dialog
- Fixed issue importing components with units and unit groups
- Fixed a bug with exporting ags 4 data for date/time fields where it would always add miliseconds
v10.0.1.992
Released 5th May 2022
- Updated app in line with security update to infrastructure
- Improved the audit dialog window to allow resizing so view more of the information on the screen
- Updated UI of the coordinates systems dialog
- changed layot of edit and delete adding buttons to the bottom on the window
- Improved the visibility of proj 4 string by adding a scroll bar. Please note proj 4 string still cannot be edited once coordinate system is created.
- Fixed typo of bulk update dialog where there are plurals
- Example is bulk update of location status field said statuss previously
- Fixed Export wizard to show the group title and not the description the group uses.
v10.0.1.969
Released 19th April 2022
- Improved picklist manager behavior so it will save a new picklist group on import of picklist csv's.
- Previously if a new picklist group was added without saving the group name first if the picklist csv was imported there would be errors.
- Now the if a new group is added the picklist manager will save on import of new picklist csvs so the error doesnt occur.
- No other changes to picklists have been made apart from the above
v10.0.1.951
Released 18th March 2022
- Fixed a bug which would crash the app preventing adding new picklist values to groups
- Fixed a bug with snapshots which under certain conditions would restore locations it shouldnt
v10.0.1.940
Released 14th March 2022
- Added a Default Profile column to the main Report Profile dialog to make it easy to indentify which profile is the default one.
- Updated version of Data Forensics Soil Classification Plugin
- Fixed a bug which would show the temp folder path in the status dialog during data import when there was a failure under certain circumstances
- Improved the UX for the picklist manager dialog so it doesnt close when save is pressed
- This improves the experience as you dont need to keep opening the dialog when you want to save changes or import more via csv.
- Recycle bin improvement
- Changed the button design so its more subtle
- fixed text format issues
- added a message to dialog to state deleted projects in the recycle bin will be permanantly deleted after 90 days
- added a new cloumn with a days remaining before deletion count.
v10.0.1.923
Released 17th February 2022
- Infrastructure improvements
- Added a new recycle bin feature to restore deleted projects (Info on this can be found here)
- Fixed a bug with the api service for downloading bgs data
- fixed a bug with importing single csv so that data import rounds decimals to the display format when comparing key fields
- added appropriate header when importing csv where the header is not in the mapping file
- changed wording of role can manage project to say "enables viewing of all projects"
- fixed a bug with csv mapping would hang when deleting.
v10.0.1.872
Released 20th January 2022
- Added a time zone offset in the Professional error logs which notifies developers of users region for debugging purposes
- Fixed a bug with default log previewing after migrating to the cloud
- Lengthened the picklist selection drop down box in grids to make it easier to select from a large list
- Exporting data with a lot of locations was using more memory than needed so its now moved to the large task queue
- Fixed an issue with log templates not scaling horizontally correctly when they are on a combined log user master templates
- Fixed a bug with imperial sections not showing the correct horizontal scale
- Fixed an issue with quicklogs and log reports created in Studio when the margins were outside the size of the merged cell area.
- The issue would present with a generic error which is unhelpful.
- It is now ignored so the log can be viewed
v10.0.1.852
Released 05th January 2022
- Fixed an issue with OIDC authentication where it would prompt users to sign in again on a frequent basis.
Released 26th November 2021
- Fixed a bug which caused the app to crash when using the reset project location tool
- Fixed a bug which would show log orientation as portrait when it was set as Landscape. This fix is more of an issue when using the Data Collector as currently its not possible to change orientation on that app.
- Added a small tooltip to all grid counts to confirm the grid count is filtered.
v10.0.1.806
Released 18th October 2021
- Fixed a bug which would crash the app if grouping was applied to the office field and the saved search button was pressed. This button shouldn't be enabled at system level so is now greyed out.
- Fixed a bug where log reports wouldnt work if the templates contained strips with the hide option enabled for strips with dynamic scaling applied.
- Fixed a bug where it wasnt possible to go back and edit tests in a test schedule.
- Impoved the picklist manager by allowing multiple selection of picklist values for deletion. Can use the shift key and select to choose more than one, allowing bulk deletion
- Removed the tree counts in the project explorer for the report folder (excluding validation reports) This will improve tree load performance.
- Updated the create Config Pack dialog to remove the text which was innaccurate as it would always state "create config pack from existing project" Also removed the "s" from the text "create config pack" as you can only create one pack and not multiple as the title would previously imply.
v10.0.1.798
Released 8th October 2021
- Fixed a bug which can create duplicate parent tables when creating new filtered grids in the model manager
v10.0.1.791
Released 28th September 2021
- Fixed an import issue which would cause duplicate key field validations if data was roundtripped.
- This issue was caused by import of config packs with fields that have greater precision to existing config packs same fields
- Fixed an issue with adding project/office logos
- Fixed a bug which would crash the app if you try to add words to the dictionary
- Fixed a timeout issue with saving large Trigger Sets
- Added Project Unlock message when add/edit button is pressed or Data Entry
- Improved bulk update dialog to not have the save button enabled until something is actually entered
v10.0.1.780
Released 20th September 2021
- Fixed a bug crashing app by preventing users from uploading non images to the Template Images dialog
- Fixed a bug with calculated fields not reprocessing on import of data
- Fixed a bug so users are able to create calculated fields with the Integer data type
- Removed legacy report issue to Keynetix as no longer relevant
- Fixed a bug with user roles permissions where in some cases the incorrect roles would be applied and in some users with can manage configurations role couldnt access all of the config ribbon
- Added the ability for users with "can manage configurations" role to unlock projects where imports have failed and locked said project
v10.0.1.770
Released 15th September 2021
- Hot Fix for adding project/office logos (US Region only) A permanant fix for all regions will be released shortly.
v10.0.1.751
Released 20th August 2021
- Fixed a bug which would cause the app to crash when pressing cancel after pressing export documents
- fixed an issue where dxf and shape files wouldnt import
v10.0.1.733
Released 09th August 2021
- Updated app to support migration to Azure Cloud Infrastructure
v10.0.1.681
Released 05th May 2021
- Fixed a bug with importing hbc of model entities which have had custom fields mapped in a project and then the hbc is imported into a different project.
v10.0.1.673
Released 23rd April 2021
Added a Project Centroid reset location button to the Projects map. This will now update the projects lat and long based on the locations centroid.
Fixed a bug with default locations mappings styles where there could be errors with saving updates
Updated the coordinates systems so you cannot remove Bing/Google WGS84 and World Geodetic System Longitude WGS84 systems. Removing them previously would cause other issues related to the map.
v10.0.1.654
Released 30th March 2021
- Added component drop down option for transferring Mobile Data Entry Profiles
- Fixed a bug with system model crashing when selecting manage grids for tables like Project
- Added ft scale for the line measure tool which shows ft after it shows m
- Fixed a bug which allowed importing of logs with the same name via hbc. A validation warning now shows
- Adding text wrap to the import wizard so no text is cut off requiring the table to be resized
- Fixed a bug with snapshot creation where it would fail in certain instances
v10.0.1.637
Released 01st March 2021
- Fixed a bug with depth joining where it was possible to create a circular depth join which would break the table used in the depth join process.
- New validation has been added to prevent the ability to create a circular depth join.
v10.0.1.625
Released 11th January 2021
- Add the missing filter button to the Project Acress Security Group field, this will enable Admins to fitler which users have what type of access to the selected project quickly.
v10.0.1.621
Released 04th January 2021
- This update contains the database model updates for AGS 4.0.4 changes. These changes have been communicated in the following communities article:
v10.0.1.616
Released 13th Novemeber 2020
- Left aligned all numeric fields in the clouds grids. This was added to ease viewing of data in each grid.
v10.0.1.612
Released 12th November 2020
- Fixed a bug with error message handling for entering coordinates for locations that are out of bounds of that coordinate system
- Fixed a bug with downloading source data from the manage imports dialog
- Added caching for large picklist images
- Fixed a bug with the create template dialog which would crash before the add tests screen.
v10.0.1.601
Released 05th October 2020
- Fixed a bug with grid editing where the app would lock up if the grid was in edit mode for over an hour.
- Fixed an issue with importing documents via pLOG where the target projects units were different from the pLOG projects. E.G an project in imperial units imported into a OpenGround Professional project in metric.
v10.0.1.596
Released 24th September 2020
- Fixed a bug where filtering the list of picklist groups to find user selection would crash the app when the user goes into the chosen groups and then closes the window.
- Fixed a bug with detailed descriptions on logs not showing correctly on the following page. Scale would also affect it.
v10.0.1.593
Released 12th August 2020
- Added ability to export documents along with project data via CSV
- Added support for the creation of Multi Grids within the Manage Grids dialog of the Configuration Pack Model
- This allows data to be filtered into different tables based off a specific picklist value added to the main table
- Added enhancements to Dynamic Logs which shows log data on same page when there is a change in type.
- Changed the way Date/Time values are handled so the time entered is consistent regarless of where data was entered in the world.
v10.0.1.572
Released 09th July 2020
- Sped up the transfer mapping import process, to prevent timeout which could blank out original mapping before updating.
v10.0.1.565
Released 02nd July 2020
- Fixed an issue where adding WMS layers using secured passwords wasn't processed correctly
- Fixed a bug which can cause issues if you remove parent key fields from the grid view in manage grids.
v10.0.1.540
Released 10th June 2020
- Fixed a bug where log preview would not show the correct strip set in the drop down on load despite the correct strip set being shown on the log correctly
- Fixed an issue where closing opened logs would not clear the sub process from the task manager which would consume more memory over time
- Improved cloud log error messaging- will notify users why the log fails to generate if there is missing fields or the image grid size is outside of set criteria
- Fixed an issue where if a table had depth linking to geology i.e Sample Information if the user chose to not import strata details it would still import that table and overwrite records.
- Changed manage imports dialog to now display correct product name for Import source i.e OpenGround Cloud Professional
- Fixed a bug where data couldn't be submitted to BGS
v10.0.1.515
Released 28th May 2020
- Added improvements to OIDC Authentication workflows and app stability
Release of OpenGround Cloud
Released 25th April 2020
- Release of OpenGround Cloud and related applications
All of the notes below are relating to Keynetix.cloud and related products. These are included here for historic purposes.
v10.0.1.430
Released 30th March 2020
- Fixed an issue with the audit history which would affect the query to fetch updates locations only on data export.
v10.0.1.412
Released 27th February 2020
Added Functionality
- Fixed a bug which prevented test schedules from being created via the chemtest connection.
- Fixed a bug where adding a document to a project with no location wouldn't show the added document
- Fixed a bug where data export filter by date wasnt picking up locations where the child tables had been modified.
- Fixed a bug which stopped the reload button for quick logs to show until you clicked somewhere on the page
- Fixed a bug which duplicated the initial import steps after data was queued via the portal.
v10.0.1.388
Released 11th February 2020
Added Functionality
- Component Export for Templates is now grouped under the category of "Report Templates"
- This grid has filter capabilities and components can be grouped by Template Type.
- As an additional benefit when exporting a Master Template the exported hbc will also include all the strips and the strip set links so they do not need to be exported separately.
- Improved data export capabilities by adding the following options:
- Can filter locations based on Status
- Added a date picker option to export locations which have been modified on a specific date only. This removes the need to export every location when you only require those which have recently been updated.
v10.0.1.369
Released 10th January 2020
- Fixed a bug with deletion of data, the following scenarios were affected:
- Locations added to a Location Group and those locations were then deleted. In this scenario the child data deletion cascade would not occur, this would mean that the tree count wasnt update to reflect the change and if the Location data was re-imported the plan would be inaccurate.
- Samples added to a Test Schedule and those samples were deleted. In this scenario it wouldn't be possible to delete the samples and there would be an error message confirming a problem with deleting.
- Fixed a bug with displaying strip sets on combined log, the log would show the strips not at correct widths.
v10.0.1.361
Released 13th December 2019
- Fixed a bug preventing site plans from being generated
v10.0.1.359
Released 11th December 2019
- This release contains updates to Borehole Log Templates, this includes the addition of a new template type called Dynamic Templates
- A new button has been added when doing a quicklog for a dynamic template which allows for switching strip sets used for the template type.
v10.0.1.348
Released 29th November 2019
- Updated app with new api security
v10.0.1.324
Released 11th November 2019
- Fixed a bug where in certain circumstances importing a list of projects and locations via CSV wouldn't have them show in the Projects grid but they would appear on the Projects Map.
v10.0.1.315
Released 25th September 2019
- Improved pLOG project downloads by adding a filter category for location status
- Improved progress reporting for pLOG imports.
- Fixed an issue preventing pLOG importing where there were documents attached that do not exist
- if the option to include documents is selected then the import will complete by stepping over the missing documents
v10.0.1.309
Released 27th July 2019
- Strip sets are now ordered alphabetically in the quick log drop down menu
- Fixed a bug where strip set header legend key values were doubled in size when displayed on a master template
v10.0.1.299
Released 11th July 2019
- Fixed a bug with importing data which contains special characters.
- This bug affected the use of data written in foreign languages.
Fixed display of connector symbols being used for range symbols on logs where previously if the connector carried on to the next page it would not be displayed. (Tile Y Selection only)
Fixed a bug with displaying the ground scale values correctly if the hole had any inclination values applied.
- Fixed a bug where setting a template for the config pack wouldnt load it in the project associated immediately.
v10.0.1.287
Released 20th May 2019
- Fixed a bug with quicklogs/log reports displaying. The bug would prevent previewing of the template where there was a vertical scale added which had the flag set for display ground level scale and the locations ground level was greater than 0 but less than 1.
- Fixed a bug with combined logs displaying duplicate data for range text box items where the data is on the transition depth.
v10.0.1.282
Released 7th May 2019
- Added a message that informs users they need to apply filtering to a table which contains over 1 million records. This is in place to improve performance of the cloud.
v10.0.1.275
Released 30th April 2019
Features:
- Added import of datasets from DXF and Shape file formats.
Bug Fix:
- Fixed a bug with reprocessing of calculations in tables that also contain date/time fields.
v10.0.1.269
Released 16th April 2019
- Fixed a bug with displaying of combined logs when a straight line is used at point of log transition.
- Originally the logs would have data duplicated and squashed on the transition line.
- Fixed a bug which didn't display a groups Project Explorer folder location in the model manager.
- Fixed a bug which caused Enterprise to crash when tabbing through the grid during picklist creation.
- Fixed a bug where setting a master template in the components manager to inactive would remove it from the dialog completely.
- Fixed a bug when attempting to view previous versions of uploaded documents would cause Enterprise to crash.
- Fixed a bug which caused a failure of Export if the "create file per location" option was selected.
- Increased app security.
v10.0.1.262
Released 11th April 2019
- Improved the handling of snapshot restoration when other users are working on other projects.
- Snapshots not longer lock the database preventing use while transaction is processed.
- Fixed a bug where snapshots were not created on import when the checkbox is selected.
v10.0.1.255
Released 5th April 2019
- Fixed a bug which allowed picklist values currently in use to be deleted.
v10.0.1.251
Released 29th March 2019
- Fixed a bug where entering any data for a field of the data type "TimeSpan" and Display Type duration would not commit correctly. When the grid refreshed the data would be removed.
- Fixed a bug where there were duplications of sample records used in a test schedule where more than one test was scheduled.
v10.0.1.237
Released 11th March 2019
- Added improved error messaging for cloud importing which details the reason for the import error and not provide the user a generic red error with no explanations.
- Enhanced the import performance for CSV and gINT data. The speed of importing is now improved
- Included progress messages for longer imports to inform the user what is currently happening. For example if any plugins are currently being run.
v10.0.1.227
Released 15th February 2019
v10.0.1.226
Released 28th January 2019
- Fixed a bug with the bulk Project Locations importer which would previously produce validation error messages preventing import. (Please note that the importer is currently limited to 500 project locations in one go).
- Fixed a bug which would cause Enterprise to crash when attempting to delete multiple rows of data using the delete key on the keyboard.
v10.0.1.200
Released 19th November 2018
- App is updated to support the enhanced security changes to cloud infrastructure.
v10.0.1.197
Released 1st November 2018
- Fixed an issue where an error would occur when enabling a custom field that uses a calculated expression inside a project and, reprocessing all project calculations which contain the same custom field in that table.
v10.0.1.194
Released 29th October 2018
- Added extra Quick Section parameters for:
- Scale Horizontally
- Hide Chainages
- Fix Log Width
- Added option to turn on/off strips shown on the section.
v10.0.1.189
Released 01st October 2018
- Added Master Template support for selecting Master Template and available strip sets for use on Quick Logs and Log Reports.
- Added an Administrator Portal for System Administrators to track licence usage for all apps and remove a users licences if needed. access via adminportal.keynetix.cloud
- Added an improved web based pdf browser for log display. This improves rendering of logs and also can detach the log viewer without losing what is displayed.
- Name of Cloud currently connected to is displayed in the top bar of Enterprise.
- Added the function to add new coordinate systems by entering the correct Proj4 String.
- Added the function to delete coordinate systems.
- Added coordinate selection drop down for choosing either Northing/Easting or Lat/Long when changing coordinate systems recalculations after project has been created.
Bug Fixes
- Fixed a intermittent bug where a red error would appear when doing a quick log
- Fixed a bug where it was possible to close the calculated field processing dialog whilst HoleBASE was stilling processing.
- Fixed a bug where the project selection dialog for running calculated fields would show all projects and not just projects created in the config pack selected.
- Fixed a bug which prevented adding Geology Top and Base to a different grid using Depth Joining.
- Fixed a bug where Enterprise would crash if trying set certain component types to inactive when they are not allowed to be.
- Fixed a bug where importing component types for Civil Extension Profile Templates, Data Entry, Model and Picklist would time out and cause and error.
- Added a progress indicator for deleting components as previously could crash the app.
- Fixed a bug where Sections would fail when no default template has been set under "manage templates"
- fixed a bug where trying to save a new security group without including a mandatory field would remove the selection box for choosing whether it was a system of project level group.
- Fixed a bug with the validation response for when no lab has been selecting when adding a new test type.
- Added correct validation error message for when lat/long are out of bounds for that coordinate system.
- Fixed a bug with graph/boundary line styles where you would get an error if you create a new style and delete it before saving.
- Error message handling for when importing a csv whilst the csv is still open in Excel.
- Fixed a bug when trying to import a component that isnâ€t signed. Previously would cause and error now correct validation message is displayed.
- Fixed a bug where there wasn't the correct validation response failure to location template doing quicklogs.
- Fixed a bug with importing specific report views would fail
- Fixed a bug where the import wizard would return warnings for unit validation where the group being warned isn't in the import file.
v10.0.1.182
Released 13th September 2018
- Fixed an issue with the way date/time fields are handled via data entry.
- Users Geographical Region when entering time can be different to cloud server location. That can mean the time entered is changed when data is committed.
- Added a Time offset to take into consideration time zone differences based on UTC.
v10.0.1.151
Released July 2018
- Improved the performance of grid editing.
- Updating fields in tables that were linked to other tables via a calculated field could cause significant degradation, this is now improved
- Fixed an issue with editing parent key fields in child tables where previously if the parent field was amened the key field in the child table would not update correctly.
- Fixed an issue with adding calculating fields outside of a project.
- Improved dialog loading times across the system.
