The below information will take you through the updates that are specific to this application. For more general information and product update videos, please see the general New Release page
v10.0.2.53
Released 25th August 2026
- Fixed a bug with strip alignments in Civil 2025/26
v10.0.2.44
Released 1st June 2026
- Bug fix for incorrect borehole orientation when orientation and inclination values are null
- Fixed profile strip scale
- Fixed a crash bug where manual borehole selection on sections caused the app to crash on second edit
v10.0.2.31
Released 24th February 2025
- Added support for C3D 2025 and 2026*
- *There is a known limitation with the current install file for languages other then English (Including British English, which is installed separately from English). If you have issues installing the extension please contact Bentley Support Portal - Customer Service or OpenGround Professional Services.
v.10.0.1.1749
Released 12 August 2025
Released 27th February 2025
v.10.0.1.1696
Released 21st January 2025
- Fixed a bug where app would crash when opening projects
v.10.0.1.1690
Released 12th December 2024
v.10.0.1.1659
Released 25th April 2024
- Added support for Civil 3D 2024
v.10.0.1.1656
Released 16th April 2024
- Installer fix removing sqlserver types
v.10.0.1.1647
Released 26th February 2024
- App updated to support the new functionality for Report Options. This is being added in an upcoming release of OpenGround Professional
v.10.0.1.1640
Released 5th September 2023
- Bug fix to show a message when a user is trying to open the app on a cloud where the user is not active in.
v.10.0.1.1630
Released 30th June 2023
v.10.0.1.1617
Released 3rd May 2023
- Updated app with security update
v.10.0.1.478
Released 28th February 2023
- Enhancement to performance of rebuilding profiles by excluding text elements with null data
v.10.0.1.474
Released 10th January 2023
- Added support for Civil 3D 2023
- Added the ability to support Local Grid coordinates data import from Professional.
v.10.0.1.442
Released 8 October 2022
- FEDRAMP compliance application shut down logging
v.10.0.1.432
Released 12 October 2022
- FIPS compliant app update
v.10.0.1.424
Released 22nd August 2022
- small update for app security
v.10.0.1.418
Released 16th June 2022
- App updated Config Pack Model enhancements
v.10.0.1.414
Released 31st May 2022
- Fixed a longstanding issue with app not authenticating due to an issue with newtonsoft
v.10.0.1.406
Released 19th May 2022
- Updated app due to mandatory update for data collector update 3 support
v.10.0.1.404
Released 13th May 2022
- Added function to create styles using project level civils sections created in Studio.
- Critical update needed so project section styles are only selectable when saving to project and not config pack
v.10.0.1.395
Released 5th May 2022
- Updated app in line with security updates to infrastructure
v.10.0.1.391
Released 14th March 2022
- Improved the authentication process which previously could prevent the app from loading
v.10.0.1.389
Released 17th February 2022
- Updated in line with infrastructure update
v.10.0.1.382
Released 20th January 2022
- Fixed an issue with split profiles causing an error on rebuild
v.10.0.1.379
Released 19th October 2021
- Fixed a bug with updates not working when locations are moved via the mapping funtion in OGPro.
v.10.0.1.370
Released 30th September 2021
- Fixed an issue with hatch borders not being shown correctly in certain situations for plan strips and profiles.
v.10.0.1.366
Released 10th September 2021
- Fixed user permissions so that only users who have the role "can manage configurations" at project level can add/edit/delete hatches and styles as project level only.
- Those who have the role at system level can save to config and project
- those without cannot save styles or hatches at all
v.10.0.1.361
Released 20th August 2021
- updated app to fix an issue some users have experienced with the app not loading projects.
v.10.0.1.346
Released 9th August 2021
- Updated app to support migration to Azure Cloud infrastructure
v.10.0.1.335
Released 16th June 2021
- Fixed a bug where deleting an orientation and inclination record and adding the same record with differernt values would cause a profile to display the borehole at the wrong angle
- Fixed a bug where updates wouldnt work if users are in a timezone lower than UTC e.g -5:00 US East.
v.10.0.1.299
Released 04th January 2021
- This update contains the database model updates for AGS 4.0.4 changes. These changes have been communicated in the following communities article:
- Fixed a bug with hatch order display on strips. Hatches on civil strips were being displayed in alphabetical order, they should be displayed in order the way they appear in dialog. This has been resolved
v.10.0.1.296
Released 14th October 2020
- Enabled the display of civil strip centre column for header lables which was added to the latest Studio released.
.v.10.0.1.290
Released 2nd October 2020
- Added ability to display actual locations Eastings and Northings on Profile Strips
v.10.0.1.271
Released 12th August 2020
- App updated in line with latest updates to the Cloud API changes for Multi Grid Support
v.10.0.1.259
Released 02nd July 2020
- Fixed a bug where authentication would fail for login if the user had the desktop version of the Civil 3D Extension installed alongside OpenGround Cloud Civil 3D
v.10.0.1.252
Released 28th May 2020
- Fixed a bug where updates wouldn't complete in instances where strata were removed or updated (not always but in certain scenarios)
Release of OpenGround Cloud
Released 25th April 2020
- Release of OpenGround Cloud and related applications
All of the notes below are relating to Keynetix.cloud and related products. These are included here for historic purposes.
v.10.0.1.220
Released 30th March 2020
- Fixed a bug where dynamic scale for graphs on strips wouldn't show correctly based on data being presented.
- Fixed an issue with the audit history which would cause issues fetching updates.
v.10.0.1.198
Released 27th February 2020
- Updated app in line with changes to api and security
v.10.0.1.190
Released 11th December 2019
v.10.0.1.187
Released 29th November 2019
- Added ability to display plain and slotted pipe references for installations.
v.10.0.1.186
Released 20th November 2019
- Fixed a bug where materials were not displayed in the hatch manager
v.10.0.1.179
Released 11th November 2019
- Removed the database ID flag which for some cloud users who had their on premise databases merged and migrated to the cloud would not be able to connect their drawing files to their projects.
v.10.0.1.164
Released 19th September 2019
- Added new USGS Hatch patterns which can be used in Enterprise when the following hbc is imported
v.10.0.1.160
Released 16th August 2019
- Fixed a bug where profiles would crash on rebuild in certain circumstances due to invalid extends
v.10.0.1.152
Released 14rd May 2019
- Fixed a bug with displaying strip headers for plan and profile view.
- When data isnt present in one of the headers that header label would overlay on top of the header next to it which contain data.
- Fix will hide strip headers where no data is present in them.
- Improved error handling for fences when they crash on rebuild.
- Fixed a bug where the can manage geotechnical layers role wasnt working correctly
v.10.0.1.144
Released 30th April 2019
- Fixed a bug with CAD crashing on profile rebuilding under certain circumstances.
v.10.0.1.143
Released 23rd April 2019
- Fixed an issue where CAD would crash on using the Geology Interpretation "follow" command in specific situations.
v.10.0.1.135
Released 16th April 2019
New Functionality added:
- Persistence of Interpreted data is now possible (BETA)
- Added Load and Save buttons.
- Load- will allow users to create a Ground Model interpretation after edits as well as loading existing edits in a new drawing.
- Save-will let users save what has been edited to an existing ground model interpretation or save a brand new one.
- Added Follow and Trim functions.
- Follow will copy the selected strata and use its interpretation for a different profile line by selecting a starting point and using the mouse to choose which side of the line to trim..
- Trim is use for quick undo of a part of a selected profile line
- Can also save non geotechnical profiles which can be restored to a new drawing. They are called supplementary profiles and can be found in the save menu.
Bug Fixes:
- Improved handling of fences which have been modelled.
- Prevention of application hanging in situations where fences have been modelled.
- Improved error reporting by showing when fences fail to generate.
- Improved app security.
v.10.0.1.134
Released 11th April 2019
Fixed an issue where in certain circumstances CAD would crash when rebuilding profiles.
Issue found in 2019 Civils.
v.10.0.1.127
Released 29th March 2019
Fixed a bug with displaying section strips where inclination was set as 0 in Enterprise. The plan view would show the inclination correctly but the section would flip it.
v.10.0.1.120
Released 11th March 2019
Fixed a bug where if data was added to the Orientation and Inclination table with empty record for Inclination Civils would treat it as 0 degrees. It is now treated as 90 degrees.
v.10.0.1.115
Released 13th February 2019
- Fixed a bug where manually removing a borehole from a profile would remove all of them if the profile alignment was curved.
v.10.0.1.113
Released 11th February 2019
- Enhanced geology modelling performance on the cloud.
v.10.0.1.109
Released 06th February 2019
- Fixed a bug where profiles would crash if created using "other surfaces"
v.10.0.1.104
Released 28th January 2019
- Added the option to create project level hatches and styles.
- Hatches can be copied to the project edited and saved so they will be only used for that project, same with styles.
- New Styles and Hatches can be created to be used within the project created in and not shared across all projects that share the same Configuration Pack..
- Project level styles and Hatches can be copied to the Configuration pack
- Fixed a bug where the Hatch Manager would show duplicate hatches if the same picklist name was used for a different geology type.
- An example of this is CL used for Geology Code and cl used for Geology Code 2. CL would appear twice in the hatch manager but it is the same picklist so deleting one would remove both.
v.10.0.1.89
Released 19th November 2018
- App is updated to support the enhanced security changes to cloud infrastructure.
v.10.0.1.88
Released 07th November 2018
- Fixed a bug with rebuilding profiles which contain duplicate hatch names in use for separate geology references (e.g Legend Code or USCS)
- Fixed an issue with hatches being displayed inconsistently in front or behind when dual graphics library items are used for the strips. (REGEN command needed after changes in 2017)
v.10.0.1.83
Released 01st October 2018
- Fixed a bug where updating changes to the drawing made from HoleBASE Enterprise edits wouldnt be picked up immediately due to difference in time stamp from change made on the machine to the cloud server which could be in a different time zone.
v.10.0.1.80
Released 13th September 2018
- Fixed a persistent CAD crash issue when connecting to a Project in Civils.
- Civils 2017 was affected by this crash. 2018 and 2019 were unaffected.
v10.0.1.67
Released July 2018
- Improvements made to the opening speed of the ribbon buttons.
- Added the Geology modelling interpretation to Cloud Civils
