Description Bar Object
The Description Bar object displays the geology description in the column.
To insert a Description Bar object into a column, follow the steps below:
The description is centrally aligned by default but it is possible to use the Alignment Area on the Design section of the ribbon to right or left align it.
Use the horizontal padding to create some space to the column border from the Padding Area on the Design section of the ribbon.
